16-7-2021 ACTIVITY IS BUILDING-UP TODAY !!
There is new activity in the S.E. at the limb as two AR's (one of which shows a spot at least).
AR2842 in the North is still showing just the one spot, whilst AR2841 is clearly showing up to 7-spots before it dives over the limb at the S.W.
Proms look interesting for imaging today, so three-lights should show some nice (or better) captures...
Unfortunately even though the Sun is shining here today, a new telescope has just arrived and also the new mini-observatory has too, so maybe later, I might get to the main observatory for a looksy and/or imaging. Can't do everything at once, so will be looking at the excellent images here instead...
CLEAR SKIES
- 16-7-2021 0911z 2-AR atest_4096_HMII.jpg (86.1 KiB) Viewed 410 times
- l16-7-2021 0911z AR2842 atest_4096_HMII.jpg (127.4 KiB) Viewed 410 times
- 16-7-2021 0911z AR2841 atest_4096_HMII.jpg (14.51 KiB) Viewed 410 times
- 16-7-2021 0938z latest_2048_0304.jpg (613.87 KiB) Viewed 410 times
- Has thanked: 9387 times
- Been thanked: 6201 times
Re: 16-7-2021 ACTIVITY IS BUILDING-UP TODAY !!
Thank you for the update, Terry. Work is very busy and did not have time to image, but hope soon.
Thank you Franco and like-wise here, but not being paid for the work here.
Correction:- the S.W. AR near that limb, is apparently AR2843 (not 2841), which suggests that one of the newbies in the S.E. will likely be AR2844, but I may be wrong there !!
- Has thanked: 18114 times
- Been thanked: 8943 times
Excellent news Terry, sadly cloudy this morning (only place in England). Now the Sun is out I am busy at work
- Has thanked: 2502 times
- Been thanked: 4928 times
A very nice surprise Terry, hopefully a little sunshine here where I live, after all that rain.
I hope you and all our other forum members in Belgium, Germany, Netherlands and Luxemburg are OK Maurits.
Stay safe!
Stay safe!
- Has thanked: 17976 times
- Been thanked: 17117 times
You need you a pair of 8x32 Lunt SUNoculars for a quick view!!!
Terry,
It's an exciting day for you! Good luck on getting everything set up and ready. But new scopes attract clouds!
Ha Ha James, that sounds about correct, although today has been beautifully clear blue skies and getting warmer (too warm) too.
All these new presents (I wish they were presents) will be keeping me extra-busy for some time - I guess...
As I have now unpacked the newbie and all looks ok, the newbie is a Sky-Watcher Esprit 80ED Super APO TRIPLET. Looks very well made and it will probably get its' first airing on the Moon or night-sky first, as it is hoped it will eventually replace the Orion ED80T-CF on the Solar tri-scope assembly.
It took two-months from ordering, but hey can't expect much better due to the obvious situation..
The Orion scope will probably be used in the mini-observatory for Lunar and WL-Solar purposes later-on and specifically when during the Winter-months the Sun is low in the south...
I've got a Solar-equipped spotting-scope (ready on its' tripod) for quick looks, so don't miss too much in WL at least...
Unread post by Montana » Fri Jul 16, 2021 1:41 pm
Stay safe!
Thanks Alexandra and I certainly re-iterate your comment...
Well you've said it so many times about being busy when the skies are clear, so I can suggest that this weekend (until Tuesday even) you should get some Sun-bathing time for your scopes at least.
Thank you Maurits and likewise for your weather and the other side of the North Sea from me, is looking good for the next few days as a nice high-pressure region has taken over, so hoping you also get some Sun-bathing too... !!
To everybody then, PLEASE STAY SAFE & VERY WELL and wishing you CLEAR SKIES too.
Stay safe!
- davidem27
- Has thanked: 82 times
- Been thanked: 247 times
Greetings for the new baby, Terry!
Calcium II K: Lunt B1200
www.volpetta.com
www.volpetta.com
Thank you David and just had a glimpse at your website before dinner, so that will be an interesting look at - this evening.
Thanks also to Ivan and nicspenceryork (on the other-side)...
Best Wishes
Best Wishes
A Sky-Watcher Esprit 80ED triplet! Nice! You should enjoy that!!
Thanks again James and hopefully will prove itself as being better than its' predecessor and at least one of the existing Altair cameras will allow a full-disk capture without any FR's and the Barlows should perform better through it too..
The focus-system and its' locking device is exceptional compared to anything-else on any of my gear...
Will be producing some images of it and it's hi-spec transport-case etc., possibly tomorrow with the techie-stuff too.
While my C102 and AT72EDII do beat my Orion70 I can't complain about the little scope at all. It's only weakness is the focuser but it does work. It was an excellent buy for 133 dollars!
That's a grand saving James for the Orion 70 and any savings now (or previously) allow for better things later - if needed.
