Just time for a quick Ca II K FD this morning as we were heading out for the day.
20210719_CaK_FD_Mono by Stuart Green, on Flickr
20210719_CaK_FD_colour by Stuart Green, on Flickr
Our old friend the X-class flaring sunspot is back (AR2838) and can just be seen on the eastern limb. Presumably it will be named AR2846 this time around. Let's hope it remains potent.
Thanks for looking.
Quick CaK FD 19th July 2021
- Has thanked: 8588 times
- Been thanked: 8324 times
- Has thanked: 17955 times
- Been thanked: 17100 times
Re: Quick CaK FD 19th July 2021
I never have figured out why they re-number them when they know it's the same system seen before.
Nice CaK images, Stu. As usual.
- Has thanked: 20940 times
- Been thanked: 10587 times
Good looking calcium disk Stu, hope you had a good day out!
Thanks Stu for your captures and the returning 2838 advice, which is now confirmed as AR2846 and may well have at least three-spots.
Hi James, the reason for re-numbering AR's as long as they produce spots, is that whilst on the 'dark-side' may well (and often do) change their format of spots etc.
If they are not renumbered, then more confusion will exist as to why an old-numbered AR's appears on the same visual-disk that other new numbered-regions co-exist and when things get really-busy (around Solar-Maxima) - there could well be so many numbered AR's with spots (coming and going) that it seems better to re-number those 'dark-side' AR's.
I suppose that the possibility of using "AR2838/AR2846" could assist following a specific AR., but then more computer-space would be required.
Also as and when the second STEREO satellite was available for 'dark-side' monitoring, then at least what happens there would also/often add new AR's which might not appear at the Eastern-Limb...
I hope that makes sense James ??
Regards
Regards
- Has thanked: 18104 times
- Been thanked: 8939 times
- Has thanked: 2501 times
- Been thanked: 4925 times
- Been thanked: 5016 times
Many thanks, everyone.
