The hi-resolution SDO image attached is showing that, as was reported yesterday, approaching the S.E.Limb, a large active region could well be interesting.
Well it is, as just on that limb can be seen a large AR (unnumbered as yet)...
CLEAR SKIES for all.
20-7-2021 AR2846 IS JOINED BY ANOTHER AR IN THE S.E.
- 20-7-2021 0841z latest_4096_HMII-SE-AR.jpg (23.71 KiB) Viewed 295 times
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Re: 20-7-2021 AR2846 IS JOINED BY ANOTHER AR IN THE S.E.
Thanks Terry, this region looks promising.
Ivan
Ivan
- Has thanked: 20440 times
- Been thanked: 10246 times
Thanks Terry, been observing it in CaK this morning, can't decide if it is a pair of spots or a spot divided by a light bridge. I couldn't see any jets etc coming from it so maybe it's quiescent...
I agree Mark, it's often difficult to define when so close to the limb, as really we are looking at these - sideways...
Another day or so, will provide us with the actuals..
Thanks Ivan and Alto.
- Been thanked: 4786 times
Seen this morning Terry, thanks for sharing.
- Been thanked: 8791 times
Thanks you Maurits and Alexandra.
Thunder/Lightening building-up over London, Kent and elsewhere, so keeping a close-eye on https://map.blitzortung.org/#6.78/51.73/0.471 in case I need to disconnect and earth-switch the aerial-farm...
- Been thanked: 4340 times
Thanks for the heads-up on the new spot Terry
- Been thanked: 4904 times
