AR12842 in Ha _250mm RCT
- Has thanked: 8415 times
- Been thanked: 8161 times
Alexandra kindly let me use her solar imaging spot in her garden this morning after I mentioned that I was looking to try a different location given the difficulties I've been having with my local seeing conditions.
Immediately I could tell there was an improvement compared with my own, although time was slipping away as early cloud prevented an early start and the conditions were getting worse almost by the minute. Alexandra's SSM was displaying brief periods of <1 arc second and some fleeting glimpses at <0.5, although the seeing conditions generally were all over the map, well north of 2 arc seconds.
21 SER captures in total gave me only a couple of decent stacked images, but that's enough to demonstrate to me that the setup works. All I need to do now is figure out a way of increasing the shutter speed so as to really freeze the action. My current setup requires 11ms for each frame.
Anyhow, here's the resulting best overall image, processed in mono and colour depending on your taste. Best viewed if you click through to my Flickr page.
20210720_Ha_RCT_Mono by Stuart Green, on Flickr
20210720_Ha_RCT_colour by Stuart Green, on Flickr
Thanks for your hospitality, Alexandra. Very much appreciated.
Re: AR12842 in Ha _250mm RCT
Two excellent presentations Stu. Very sharp and clear.
Thanks for sharing and Alexandra allowing sharing too
- Has thanked: 17667 times
- Been thanked: 8787 times
These are great Stuart such a pity the clouds didn't budge sooner, but at least they did in the end even if the seeing wasn't the best
Thanks for the company, it really made my year
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Stu, your photos and photos of Alexandra can be printed in the solar photography tutorials.
Ivan
Ivan
- Has thanked: 20424 times
- Been thanked: 10243 times
This turned out well. How much gain are you running on the camera?
- Been thanked: 4786 times
- banjo
- Has thanked: 2090 times
- Been thanked: 2859 times
Paul
- Has thanked: 9144 times
- Been thanked: 6025 times
An incredibly good image with a strong 3D feel to it, Stu. Fabulous.
- Has thanked: 6181 times
- Been thanked: 7142 times
Many thanks, everyone, and a huge thank you to Alexandra.
Hi Mark,marktownley wrote: ↑Tue Jul 20, 2021 7:59 pm This turned out well. How much gain are you running on the camera?
I kept gain to an absolute minimum in this case. Sometimes I do tweak this a little bit, but keep it low.
I've removed the red filter from the front of the etalon housing to allow more light through, but can't think of anything else 'easy' to make a significant impact.
Hi Arne,arnedanielsen wrote: ↑Wed Jul 21, 2021 8:24 am Looks very good, Stu. How many images in the stack?
Arne
I usually capture 5000-7000 images per SER and then stack 1, 5 and 10% in AS!3.
Easy, ramp the gain up. Even without powering the camera I can run gain up at 1/3 to 1/2 way along the slider no probs. The Basler is a fine camera and will take moderate gain no problem.Carbon60 wrote: ↑Thu Jul 22, 2021 6:18 amHi Mark,marktownley wrote: ↑Tue Jul 20, 2021 7:59 pm This turned out well. How much gain are you running on the camera?
Gain is the same principle as a volume knob on an amplifier, it's designed to be used / turned up...
- cmas
- Has thanked: 294 times
- Been thanked: 248 times
Looking good! Thanks for sharing these!
Images in AstroBin
Images in Flickr
Images in AstroBin
Images in Flickr
