07.17.21 Sun in Lunt50
- Ivan
- Has thanked: 3489 times
- Been thanked: 2267 times
Hello everyone,
Mosaic of 6 fragments.
Only now I was able to process the material filmed on July 17th. The conditions were not the worst, but it happens even better The main headache during processing, in addition to the fragments of different tone, was Newton's rings, which for some reason (this happens to me rarely) decided to appear on the left lower and middle fragments. This isn't the best FD's, so sorry.
I would be glad to hear your feedback and criticism.
Thanks for watching this. Full resolution is available if you open the picture in a new window.
Ivan
Ivan
- FD_color.jpg (1.19 MiB) Viewed 581 times
- FD_gray.jpg (812.76 KiB) Viewed 581 times
- FD_inv proms_color__.jpg (1.03 MiB) Viewed 581 times
- Has thanked: 20828 times
- Been thanked: 10502 times
Re: 07.17.21 Sun in Lunt50
A nice disk there Ivan!
- Been thanked: 4981 times
- Has thanked: 2464 times
- Been thanked: 4881 times
- Has thanked: 8559 times
- Been thanked: 8297 times
I always admire your beautifully even FD mosaics, Ivan. Very nice.
- Ivan
Friends, thank you very much for your kind and encouraging comments.
Ivan
Ivan
No criticism Ivan, as your imaging and processing techniques are perfect.
Thanks for sharing
Thanks for sharing
- VasilevIvan
- Has thanked: 399 times
- Been thanked: 266 times
Great FD's mosaic, Ivan!
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
- Been thanked: 8907 times
The details are absolutely fabulous
I wonder, are the NRs worse when slightly off band? this disc is slightly more off band than usual and I was wondering if perhaps the NRs were more apparent because of this. Just a thought
- Ivan
Hi Alexandra,
Thanks for your feedback. Your comments and advice are very important to me. Could you decipher what NR means?
On this day, I re-tuned the tuner, because it seemed to me that it gives a too uneven picture, I check this by making longer exposures.
After tuning it seemed to me that it got better and I did not think that I had left the strip. Although if you look at the area around AR, then it is too contrasting, while the rest of the areas are less contrasting. But it seemed to me that this was due to the difference in visibility, which changed during the filming.
Ivan
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Looks a good set to me Ivan.
David
