07.17.21 Sun in Lunt50
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Hello everyone,
Mosaic of 6 fragments.
Only now I was able to process the material filmed on July 17th. The conditions were not the worst, but it happens even better :) The main headache during processing, in addition to the fragments of different tone, was Newton's rings, which for some reason (this happens to me rarely) decided to appear on the left lower and middle fragments. This isn't the best FD's, so sorry.
I would be glad to hear your feedback and criticism.
Thanks for watching this. Full resolution is available if you open the picture in a new window.
Ivan
FD_inv proms_color__.jpg (1.03 MiB) Viewed 575 times
Has thanked: 20750 times
Been thanked: 10440 times
Re: 07.17.21 Sun in Lunt50
A nice disk there Ivan!
eroel
Been thanked: 4957 times
Post by eroel »
Ivan:
Very good FD´s.
MAURITS
Has thanked: 2463 times
Been thanked: 4878 times
Post by MAURITS »
Beautiful disk Ivan.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
I always admire your beautifully even FD mosaics, Ivan. Very nice.
Ivan
Post by Ivan »
Friends, thank you very much for your kind and encouraging comments.
Ivan
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
No criticism Ivan, as your imaging and processing techniques are perfect.
Thanks for sharing
Valtori
Has thanked: 312 times
Been thanked: 182 times
Post by Valtori »
Hi Ivan,
Very nice FD there!!
Val
VasilevIvan
Has thanked: 398 times
Been thanked: 265 times
Post by VasilevIvan »
Great FD's mosaic, Ivan!
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
Has thanked: 17925 times
Been thanked: 8894 times
The details are absolutely fabulous :bow :hamster:
I wonder, are the NRs worse when slightly off band? this disc is slightly more off band than usual and I was wondering if perhaps the NRs were more apparent because of this. Just a thought ;)
Ivan
Post by Ivan »
Montana wrote: Fri Jul 23, 2021 10:46 am The details are absolutely fabulous :bow :hamster:
Hi Alexandra,
Thanks for your feedback. Your comments and advice are very important to me. Could you decipher what NR means?
On this day, I re-tuned the tuner, because it seemed to me that it gives a too uneven picture, I check this by making longer exposures.
After tuning it seemed to me that it got better and I did not think that I had left the strip. Although if you look at the area around AR, then it is too contrasting, while the rest of the areas are less contrasting. But it seemed to me that this was due to the difference in visibility, which changed during the filming.
Ivan
Hi Ivan,
NRs = Newton's Rings
David_The_Bears_Fan
Has thanked: 423 times
Been thanked: 167 times
Post by David_The_Bears_Fan »
Looks a good set to me Ivan.
David
