2021.07.17 SolarSpectrum 0.3A vs QuarkCombo (C11-TZ3)
- Csve
- The Sun?
- Has thanked: 20 times
- Been thanked: 52 times
Hi guys!
Last weekend i have tested Valery's (@Valtori) Solar Spectrum Observer Series 1,5 0.3A filter and compared it with my Quark Combo.
Setup: Aries ERF, C11hd, Baader TZ3, SolSpec/Quark, asi174mm. To keep comparison clear i didn't even move mirror focusing knob.
SolSpec was 3 times brighter(10ms@150gain vs 20ms@240gain) if compare best tuner positions, but during capture Quark looks more contrast.
Processing results:
Just 100 frames in stack is enough for SolSpec to have excellent SNR, whereas 800 frames stack of quark is still quite noisy.
SolSpec still looks little bit wider, but it's high transmittance makes it much better than quark.
Here is very similar processing, best single frames and flats:
Quark combo Solar Spectrum Quark combo best frame Solar Spectrum best frame Quark combo flat Solar Spectrum flat Setup
Processing results:
My gallery: AstroBin DeepSkyHosting
- Has thanked: 9318 times
- Been thanked: 6155 times
Re: 2021.07.17 SolarSpectrum 0.3A vs QuarkCombo (C11-TZ3)
An interesting comparison, Csve, thank you.
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Great comparison. The SolarSpectrum 0.3A wins hands down
Pedro Re'
- Has thanked: 20813 times
- Been thanked: 10480 times
Excellent results and looks a great place to observe for good seeing.
Maybe you can describe the post processing you did to get from the raw solar spectrum image to the finished result.
Very interesting!!
I have exactly the same as you C11 / ARIES ERF / SS 0.3A / TZ3 / ASI174 and I use gain 120 and get 8-9 ms. So very close to your settings. I also noticed that my images weren't very noisy compared to when I use the same set up with WL and CaK. This I don't understand, I thought my ASI174 was really noisy, but not with the Solar Spectrum. Any thoughts?
It is great to see these comparisons and really helps. I love the observation point and I think it wonderful you can meet friends and observe together
Superb images too!! I hope you had good fun
- Csve
- The Sun?
Thanks.marktownley wrote: ↑Thu Jul 22, 2021 12:05 pm Maybe you can describe the post processing you did to get from the raw solar spectrum image to the finished result.
It's very simple this time, to make better comparison.
1. Deconvolution in AI5 2. Some pixel math in pixinsight (all further processing in PI):
Code: Select all
($T-mean($T))*(0.05/sdev($T))+0.5
3. Moving peak to 0.25 intensity with histogram transformation 4. Doubling local contrast at histogram peak That's all. I also usually make HDR at setp 3.5, but it is not fine for contrast comparison of 2 different ethalons.
The procedure was absolutely identical for both images despite initial contrans and brightness difference.
- Csve
- The Sun?
Thanks.
Asi174 still have quite large well capacity at gain 120, if you fill it, single image SNR is quite high.
Local seeing is very important i believe. Forest surface should be even better, as it heats less than grass field, but some turbulence can appear on the border.
Thanks for the comparation Csve, this is exactly what I hoped to see.
I am very interested in the Solar Spectrum 0,3A too.
My Quark's are very very good but not the image quality as the Solar Spectrum.
- Csve
- The Sun?
Quark image is worse than i expected. I'll try to repeat comparison this Saturday.
Last weekend we also (with LeoD) have compared Lunt LS80 double stack and this SolSpec in 130mm refractor. Results coming soon.
- Has thanked: 47 times
- Been thanked: 1525 times
This is very interesting. Is the major difference the higher transmittance, therefore a shorter exposure time and lower gain?
It also looks like the quark may also have some additional optical imperfections (slightly worse focus). The bandwidth does not look very different between the two etalons.
- Has thanked: 1075 times
- Been thanked: 1986 times
I'd like to see the 0.3Å solar spectrum compared to a Daystar Quantum 0.3Å
The Quark is known to be a more budget friendly point and an easier way for those who own the right type of scope to be able to try out solar.
- Csve
- The Sun?
I think so.
So do I, but i know nobody who has quantum in Moscow.
- Has thanked: 17849 times
- Been thanked: 16991 times
Nice images and comparison and what a wonderful observing site!!
- Has thanked: 8558 times
- Been thanked: 8290 times
An interesting and useful comparison. Thanks for the PI Pixel Math equation. I’ll give this a try.
- Csve
- The Sun?
Thanks. This site is near the SVO Airport. 55.933500, 37.403505DeepSolar64 wrote: ↑Thu Jul 29, 2021 4:31 am Nice images and comparison and what a wonderful observing site!!
You’re welcome
Don't forget to fine tune the constants:
0.05 - Resulting histogran width
0.5 - Resulting histogran center
- Rusted
- Has thanked: 8168 times
- Been thanked: 1943 times
Thanks you for sharing these comparisons.
The first Quark image simply looks out of focus to me.
While the SS is sharply focused.
The first Quark image has lots of over-sharpening & noise artefacts.
Typical of poorer seeing demanding extra processing to bring out missing detail.
Was there a difference in timing between capturing these two images?
EDIT: I see there was. 04.35-05.19. 44 minutes difference is not minor.
The overall background detail is "messy" on the Quark. Sharp on the SS.
The flecking on the spot penumbra easily shows the clearest difference between the two.
Just my personal opinion. Feel completely free to disagree.
Forgive me for being a complete and utter pedant.
It seems obtuse to have your telescope looking directly over a bare earth track.
When you have a huge field of naturally cool plants to choose from.
The bare earth will produce ground currents out of all proportion to the cooler, surrounding foliage.
I'd avoid pointing the telescope over that tree too.
Its vertical height enjoys greater solar heating [and convection] than the lowly plants.
- Has thanked: 3317 times
- Been thanked: 1907 times
I agree about the tree. Had the same issue at the start of my session today. Also a big gravel pile a bit later.
- Has thanked: 286 times
- Been thanked: 399 times
I also agree with Rusted's points.
Just thinking though what are we trying to prove?
Is it that the Quark is good for the money, ore something else.
Quarks are just good seconds and random, Just depends on what you want out of one, In the right hands and with a good setup they can be made to give very good results.
The Solar Spectrum on the other hand is a first grade unit that when setup, you also need a TZ, is over thirteen times the price of a Quark.
Should we not really be testing like for like and see how the Solar Spectrum compares to a Daystar Quantum 0.3A?
Rod
Rod
- Csve
- The Sun?
Dirt road and single trees impacts seeing much less than asphalt and buildings.Rusted wrote: ↑Thu Jul 29, 2021 7:51 am It seems obtuse to have your telescope looking directly over a bare earth track.
I just placed telescope at a good plane area with low grass, there is no such place on the other side of the road. Perfectionism is not the best policy.
Just comparison, make your own conclusion.
That would be great.
- Oh, I get it now!
- Has thanked: 52 times
- Been thanked: 28 times
Price of Quantum 0.3A (??mm) is almost $17k. SS SO 1-5 (25mm) 0.3A is $8k. RG18 0.3A is less than $3k here in USA. Quark is $1200. TZ-3/4 are $400. More like 4x the price of a quark and with 0.3A (plus guaranteed quality) not (maybe) 0.5A and lackluster QC. I think an ION comparison would be a better comparison for money spent.RodAstro wrote: ↑Thu Jul 29, 2021 10:08 am I also agree with Rusted's points.
Rod
PS I'm fully biased and have a RG18 on order
Not trying to argue, just pointing out the prices..
Lunt 80Tha B1800, Lunt Ca2K B1200, Solar Spectrum RG18 0.3A, Skywatcher EvoStar 150, ASI 1600MM & 174MM
- Has thanked: 1640 times
- Been thanked: 878 times
Thanks for the comparison and the PI equation!
Sorry I didn't realise there was a smaller Solar Spectrum didn't pop up when I googled it.
Big price differences over here though Quark £995, Solar Spectrum RG18 £4699, Solar spectrum 46mm 0.3A £13,349, Daystar Quantum SE 0.3A £9.958.
I still want the 46mm Solar Spectrum though as I could Just get a full solar disk through it at f30.
Cheers Rod
Cheers Rod
