23Jul - AR2846 in CAk - 200 frames vs 12 frames stacking
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
We had some sunshine today. Uncovered the C11 (working at full aperture) and did some HA and CAK imaging. The HA images were a total wash-out. The CAK images were slightly better.
With 200 frame-stacking:
With 12 frame-stacking:
I have used Neat Image to denoise and minimum pp. Can you give me your feedback on which image is more pleasant?
Thanks.
Alfred
Thanks.
Alfred
- Been thanked: 8791 times
Re: 23Jul - AR2846 in CAk - 200 frames vs 12 frames stacking
Certainly the second image is sharper but it looks like you had a terrible time with the seeing. Great shots though and glad you managed to some sunshine at last
- Has thanked: 20438 times
- Been thanked: 10245 times
Yup. second one is a cleaner image. Can you link to a 16bit unprocessed file for it?
- VasilevIvan
- Has thanked: 397 times
- Been thanked: 264 times
Nice CaK images. Second image looks sharper than first.
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
- Been thanked: 4786 times
Agreed, sometimes I have a better result with lesser frames.
- yltansg
Thanks David, Alexandra, Mark, Vasilev and Maurits for your feedback.
Mark - I used 8bit recording due to limited storage space on my Hdd. Here is the unprocessed 12 frame-stacked image.
Alfred
Alfred
- yltansg
I experimented with stacking lesser frames:
8 frames:
and even 5 frames:
I think the best image was from the 12-frame stacking.
Alfred
8 frames:
and even 5 frames:
Alfred
Do you get Autostakkert to output a 16bit tiff file?
- yltansg
Hi Mark,
Thanks for the clarification. The 16bit tiff file for 12 frame-stacking can be downloaded at: https://www.dropbox.com/s/rqjfv13zb9bpb ... 5.tif?dl=0
I noticed the beautiful post-processing you did for your CAK images viewtopic.php?f=4&t=32735. Could you use the same pp on my 16bit raw file? I would love to see how it looks like with expert post processing. Thank you.
Alfred
- Has thanked: 8418 times
- Been thanked: 8162 times
Good information and demo, Alfred.
Hi Alfred, here are the post processing settings I used on my images:
mine by Mark Townley, on Flickr
I downloaded your raw file and had a play with it in ImPPG, my settings won't work on the image, however the grab below shows the best I could get out of the data:
alfred by Mark Townley, on Flickr
- yltansg
Thanks, Mark for sharing your ImPPG settings.
Alfred
Alfred
- Has thanked: 146 times
- Been thanked: 277 times
Mark, why the difference in the number of “iterations” between what you did on your image (400)and Alfred’s ( 40)?
- AJamesB
- Has thanked: 1150 times
- Been thanked: 630 times
Would be fun to play with the 16bit version of each. I notice that sometimes the initial output image with fewer frames, before post processing, looks better than the one with more frames, but that I am able to go much further with post processing on the image that has more frames, and end up with a better final result, whereas the one with fewer frames hits a noise or artifact barrier much sooner than the image with many more stacked frames. Its not all the time though, so as others have said, sometimes less is indeed more.
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- Been thanked: 4904 times
Alfred:
Your second image is better, it is hard to get what one wants, but seeing rules all the time.
Also thanks for all the tips given in the thread.
Hi David.
Alfreds raw image has much lower signal to noise ratio than my raw image, if I apply 400 iterations to his then the result is just a snow of noise.
Here is my original file. 5000 frame avi reduced to 500 frames in PIPP, then best 64 stacked in AS3.
I normally take anywhere between 5 and 10 runs at this, stacking as above, and then open the final stacked image in AS3 and reading the quality value, which ever image has the highest quality value is the one I then process in ImPPG. This one has a quality value of 902, for CaK anything above about 500-600 I know is going to result in a decent final image. One of the images from this session had a quality value of 1750, which is the highest i've seen.
- yltansg
Hi Mark,marktownley wrote: ↑Sun Jul 25, 2021 8:21 am Here is my original file. 5000 frame avi reduced to 500 frames in PIPP, then best 64 stacked in AS3.
Thanks for providing your raw file. I will do some practices with it.
One question, what is the purpose of reducing your 5000 frame avi to a 500 frame avi in PIPP?
Alfred
Hi Alfred.
If I was to run 10 x 5000 frame avis in AS3 it would take hours, running the 5000 frames through PIPP selects the best 500 frames from each avi. Running 10x500 frames through AS3 is a lot quicker (10 times quicker!).
PIPP doesn't seem very intensive on memory, so I can still capture files and distil them down to only the best frames on the fly...
More details here viewtopic.php?f=37&t=32112
Mark, interesting, I can run 58 x 3000 ser files through ASK3 in 30 minutes while I pack away the telescope
My laptop is coal powered, indeed it is held together with tape
