Hello everyone,
Mosaic of 6 fragments.
Material dated July 18. The conditions are good, I removed three sessions, but two of them went to the basket, because one of the 6 fragments turned out to be blurred after addition. The third session had the same defects, but less pronounced, and I left it.
For illustration, I have placed one of the rejected FDs at the end, and marked the edges of the blurred area in red.
I would be glad to hear your feedback and criticism.
Full resolution is available if you open the picture in a new window.
Ivan
07.18.21 Sun in Lunt50
- Ivan
- Has thanked: 3497 times
- Been thanked: 2282 times
- FD_1500_2ms_gain33__20__color.jpg (985.55 KiB) Viewed 289 times
- FD_1500_2ms_gain33__20__gray.jpg (645.21 KiB) Viewed 289 times
- FD_1500_2ms_gain33__20__inv proms.jpg (1.28 MiB) Viewed 289 times
- FD_1700_20_dec.jpg (785.86 KiB) Viewed 289 times
- Has thanked: 2496 times
- Been thanked: 4917 times
- Has thanked: 20908 times
- Been thanked: 10564 times
Re: 07.18.21 Sun in Lunt50
It came out well Ivan. This is the frustrating thing with mosaics when seeing variability affects individual panes.
- Has thanked: 18050 times
- Been thanked: 8914 times
I know your pain, when I do my full discs with the Solarscope it is either a 6 pane or 13 pane mosaic. If the seeing is bad for just one part it ruins the whole
I usually sit and stare very hard during and capture and try to assess whether the frame will stack well or not. If I think it has been a very fuzzy capture I will repeat another capture before moving on. I then process them all and everywhere I have a duplicate I look to see which is the better and use that. This way it increases my chances of getting a decent disc in the end.
The first is a fantastic capture and shows so much detail at high res, you should be proud
- Ivan
Thanks a lot Alexandra, I do exactly the same. After I have shot all the fragments for FD, I change the settings a little and start over.
Ivan
- Ivan
Friends, many thanks to all of you for your kind words and for your attention.
Ivan
Ivan
- Has thanked: 9361 times
- Been thanked: 6193 times
