Sun FD in H-Alpha and CaK 13th of July 2021 - CaK images with new camera (ZWO ASI 183mm)
arnedanielsen
Has thanked: 6276 times
Been thanked: 7294 times
Post by arnedanielsen »
Dear friends,
Here are some FD images from July 13th.
First a FD image in H-Alpha using the Takahashi Sky-90II with Coronado 90mm/BF15, Coronado 2x CeMax and ASI 1600mm PRO.
Sun90FD_141036_Ha_(Coronado_90mm_BF15)_20210713_ZWO ASI1600MM Pro_lapl4_ap6013_Sharpened_Contrast_resize.jpg
Sun90FD_141036_Ha_(Coronado_90mm_BF15)_20210713_ZWO ASI1600MM Pro_lapl4_ap6013_Sharpened_Contrast_resize.jpg (456.33 KiB) Viewed 351 times
Sun FD in H-Alpha 13th of July 2021
For CaK imaging I've been using the ASI ZWO 178mm for a while now. This has produced nice, but undersampled, FD images at the native focal length of 360mm with the William Optics ZenithStar 61II stopped down to 46mm aperture. Using a 2 or 2,5x barlow to increase the focal length to 720-900mm gave a properly sampled image and much better results, but then of course I didn't get FD.
Wanting to get the best from both worlds I decided to buy an ASI ZWO 183mm. This camera has the same pixel size as the 178mm, but much bigger sensor allowing for FD images up till around 920-950mm.
For comparison I started out shooting using the William Optics ZenithStar 61II stopped down to 46mm at it's native focal length of 360mm.
SunCaK60_131118_CaK_(3934nm)_20210713_ZWO ASI183MM_lapl4_ap2795_out_Contrast_resize.jpg
SunCaK60_131118_CaK_(3934nm)_20210713_ZWO ASI183MM_lapl4_ap2795_out_Contrast_resize.jpg (265.57 KiB) Viewed 351 times
Sun FD in CaK 13th of July 2021
SunCaK60_131118_CaK_(3934nm)_20210713_ZWO ASI183MM_lapl4_ap2795_out_Contrast_Colorized_resize.jpg
SunCaK60_131118_CaK_(3934nm)_20210713_ZWO ASI183MM_lapl4_ap2795_out_Contrast_Colorized_resize.jpg (292.68 KiB) Viewed 351 times
Sun FD in CaK 13th of July 2021 - colorized
I then added a Coronado Cemax 2x to the imaging train. This turns out to multiply the focal length by 2,5 in this configuration and thus the focal length ends up at ~900mm. This is at the high end of the optimal sampling range for this aperture/wavelength and just fits the Sun within the field of view.
SunCaK60_135520_CaK_(3934nm)_20210713_ZWO ASI183MM_lapl4_ap9945_out_Contrast_resize.jpg
SunCaK60_135520_CaK_(3934nm)_20210713_ZWO ASI183MM_lapl4_ap9945_out_Contrast_resize.jpg (335.04 KiB) Viewed 351 times
SunCaK60_135520_CaK_(3934nm)_20210713_ZWO ASI183MM_lapl4_ap9945_out_Contrast_Colorized_resize.jpg
SunCaK60_135520_CaK_(3934nm)_20210713_ZWO ASI183MM_lapl4_ap9945_out_Contrast_Colorized_resize.jpg (364.52 KiB) Viewed 351 times
Make sure to click on links for full size images.
It's so much fun to getting a properly sampled FD image like this without having to deal with mosaics.
Thanks for looking!
Arne
Arne
Petrus
Has thanked: 1578 times
Been thanked: 747 times
Re: Sun FD in H-Alpha and CaK 13th of July 2021 - CaK images with new camera (ZWO ASI 183mm)
Post by Petrus »
Looking good as usual, Arne! Great CaK shots.
~ Petrus ~
Flickr
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Interesting description and wonderful photos, I learned a lot, thank you very much, Arne!
Ivan
Ivan
Post by Ivan »
Arne, could you take a photo of the Takahashi Sky-90II with Coronado 90mm so that you can understand how the DS is attached to the telescope, perhaps you still have a drawing of the adapter? A friend of mine is now thinking about how best to connect Sky-90 and DS Coronado90. Thank you.
Ivan
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Good images, Arne.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Beautiful images Arne.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 17923 times
Been thanked: 8889 times
Oooh that last CaK is an absolute cracker :bow :bow :hamster: just need to get rid of the dust bunny :)
Has thanked: 20738 times
Been thanked: 10436 times
Very good indeed Arne! You could unscrew the lens off the Cemax barlow and screw it direct onto the camera nosepiece which would drop the magnification factor a bit, this is what I do...
arnedanielsen
Thank you very much for your kind comments Petrus, Ivan, Stu, Maurits, Alexandra and Mark!
Ivan: The front filter is the tilt-tuning version that came with the first version of the SolarMax 90. I ordered a custom adapter from ww.PreciseParts.com to fit the dewshield of the Sky-90II. It costed around $250 and was called:
Custom adapter, Coronado SolarMax 90 Solar Filter to Tak Sky 90 Dew Shield, L=10.8 mm
Alexandra: Will do :-) I unfortunately didn't have time for flats on this session, but have done so for later sessions.
Mark: Thanks for the tip. I will certainly try that. I wouldn't mind slightly more air around the solar disc.
Arne
Arne
arnedanielsen
Ivan wrote: Fri Jul 23, 2021 9:38 pm Arne, could you take a photo of the Takahashi Sky-90II with Coronado 90mm so that you can understand how the DS is attached to the telescope, perhaps you still have a drawing of the adapter? A friend of mine is now thinking about how best to connect Sky-90 and DS Coronado90. Thank you.
Ivan
Ivan,
Here's an image of the filter attached to the dewshield...
Arne
Arne
Ivan
Post by Ivan »
Thanks a lot, Arne.
Ivan
