Ha Double Stacked Sun 26th July
- Has thanked: 20779 times
- Been thanked: 10462 times
Much to my surprise this morning dawned with clear skies, and given the weather we have forecast for the coming week I thought it prudent to make the most of things.
First job was to check out my new el-cheapo focal reducer for the full disk, which I found didn't offer enough reduction as I would have liked, so a little tweaking with the spacing of the lens in the cell and I managed to get the suns disk nicely on the chip. The use of the reducer also now does away with the Baader solar telecompressor and spacers that were used, and reduces the weight of my double stack setup by a couple of hundred grams, this might not sound much, but the overall weight is at the limit for the mount, and more importantly the weight is being removed from the end of the turning moment, so should just ease things up for the solarquest when i'm on my travels. I actually thing the cheapo reducer gives a better view than the solar compressor ever did. Scope used was a 50mm Lunt etalon on the 60/360 frac, double stacked with a Quark and then the ICX814 chipped camera.
Ha-FD-DS by Mark Townley, on Flickr
Next up I decided to try out the double stacked Coronado SM90, and using the ZWO 290mm camera along with a Cemax barlow to get me up to around f16. The seeing was really boing and it took a lot of frames distilled back to only a few to get some workable data. The 2 active regions looked great, with all that angry plage and filaments...
AR12847-Ha-DS90-f16-290mm by Mark Townley, on Flickr
AR12846-Ha-DS90-f16-290mm by Mark Townley, on Flickr
Pleased to get these as was expecting to be cloudy today, any more for the rest of the week will be opportunistic between the showers. Hope you like!
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Ha Double Stacked Sun 26th July
Brilliant Mark, similar views to what I saw today. Some amazing filaments. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Excellent captures Mark.
The exposure/processing has shown very well the action on the disk.
Thanks for sharing
Thanks for sharing
- Has thanked: 17970 times
- Been thanked: 8904 times
- Rusted
- Has thanked: 8127 times
- Been thanked: 1943 times
Those are excellent!
What is this "El-cheapo" focal reducer you talk about?
- Has thanked: 17836 times
- Been thanked: 16976 times
Mark,
I have thought about getting an el-cheapo focal reducer for the 90. What brand did you get?
https://optcorp.com/products/tpo-1-25-f ... -extension
Nice images!
Nice images!
Thanks everyone for the kind words, this is focal reducer I got https://www.ebay.co.uk/itm/383572165450
Visually both scopes are pretty contrasty, certainly all in the images is easy to the eye. The DS90 has a bit less uniformity across the disk, but is absolutely fine for these mid scale closer views... I often spend quite a bit of time taking in a visual with the DS90 as there is so much fine detail to be seen, today was no exception.
As long as it works....
- pedro
- Has thanked: 14 times
- Been thanked: 6689 times
Great DS shots Mark, lots of action
Pedro Re'
- Has thanked: 6296 times
- Been thanked: 7305 times
Thanks everyone for the kind words, much appreciated!
Very nice and delicate FD and absolutely beautiful high resolution images. A very lucky day instead of overcast!
- Has thanked: 8543 times
- Been thanked: 8278 times
Cracking images, Mark. Lovely details and nice contrast.
- Has thanked: 9307 times
- Been thanked: 6144 times
These are fabulous Mark, with your traveling kit. A pleasure to see, incredible detail and excellent contrast.
Thanks everyone for the kind words, thunderstorms here these past 2 days, hopefully Thursday morning is going to give me a window of opportunity.
- Ivan
- Has thanked: 3479 times
- Been thanked: 2260 times
Mark, these are wonderful pictures, wonderful processing, I would say that these are reference pictures to be looked up to.
Ivan
Ivan
- minhlead
- Has thanked: 739 times
- Been thanked: 1107 times
Excellent shot, Mark.marktownley wrote: ↑Mon Jul 26, 2021 12:39 pm Much to my surprise this morning dawned with clear skies, and given the weather we have forecast for the coming week I thought it prudent to make the most of things.
I am interested in the reducer you are using since I am intending to make fulldisk animation myself. I posted a question about reducer here. Would you mind take a look? I 'd like the name and brand of the reducer you are using. viewtopic.php?f=4&t=32839
Minh.
Loves from Viet Nam <3
My gear:
Mount: JTW Tridents GTR
Camera:
PlayerOne Apollo M-Max
My gear:
Camera:
Thanks Minh, it's just a generic cheap unbranded 0.5x reducer...
- minhlead
Do you experienced vignetting with this? Since I got horrible vignetting with a similiar 1.25 inches chinese reducermarktownley wrote: ↑Fri Jul 30, 2021 11:39 am Thanks Minh, it's just a generic cheap unbranded 0.5x reducer...
Minh.
My gear:
Camera:
My gear:
Camera:
Nope, just got to get the spacing from chip right.
- minhlead
How much spacing did you use?
Minh.
My gear:
Camera:
My gear:
Camera:
Not sure really, added about 4 or 5mm on top of the reducer to chip distance. Just really till I got a frame with a reasonable amount of space around the sun and edges of chip for any mount drift...
- minhlead
Could you please take a picture of how you attached the reducer to your camera please?marktownley wrote: ↑Fri Jul 30, 2021 12:42 pm Not sure really, added about 4 or 5mm on top of the reducer to chip distance. Just really till I got a frame with a reasonable amount of space around the sun and edges of chip for any mount drift...
Minh.
My gear:
Camera:
My gear:
Camera:
- minhlead
Thanks, Mark!marktownley wrote: ↑Fri Jul 30, 2021 12:49 pm It's c-mount, so it just screws on
P1010252 by Mark Townley, on Flickr
What camera are you using?
Minh.
My gear:
Camera:
My gear:
Camera:
- minhlead
Hmm. Interesting. AFAIK, reducer will only provide a illuminated field about half of the reducer's aperture . In this case a 1.25 inches with 22.5mm clear aperture will have 11-12 mm illuminated field at best. You sensor is 16mm in diagonal. Do you experience vignetting with this reducer?marktownley wrote: ↑Fri Jul 30, 2021 2:43 pm Hi Minh, it's a FLIR Grasshopper 3 U3916M
https://www.edmundoptics.co.uk/p/gs3-u3 ... era/30337/
Minh.
My gear:
Camera:
My gear:
Camera:
I get the full sun in 'one take' as per the images, if I crank the exposure right up you can see the image circle, the very corners of the chip will be vignetted, but that doesn't matter as the sun isn't there...
- minhlead
Oh ok. I Get it now. If it's not too much trouble. Could I ask for a stretched raw frame so I can see how big the image circle are on your sensor?marktownley wrote: ↑Fri Jul 30, 2021 3:42 pm I get the full sun in 'one take' as per the images, if I crank the exposure right up you can see the image circle, the very corners of the chip will be vignetted, but that doesn't matter as the sun isn't there...
Minh.
My gear:
Camera:
My gear:
Camera:
Will have to be next time I image a full disk, have spent the afternoon decluttering the hard drive of solar stuff going back to may. I will when I can, maybe sunday, looking at the weather...minhlead wrote: ↑Fri Jul 30, 2021 3:52 pmOh ok. I Get it now. If it's not too much trouble. Could I ask for a stretched raw frame so I can see how big the image circle are on your sensor?marktownley wrote: ↑Fri Jul 30, 2021 3:42 pm I get the full sun in 'one take' as per the images, if I crank the exposure right up you can see the image circle, the very corners of the chip will be vignetted, but that doesn't matter as the sun isn't there...
If it helps, the sensor is 3300x2700 (ish) and I run a ROI of 2600x2500 when I image, solar disk is just over 2400 pixels across, not measured it, but is roughly that big...
- minhlead
Thanks, Mark. If you have that image, just give me a message will you?marktownley wrote: ↑Fri Jul 30, 2021 3:58 pm If it helps, the sensor is 3300x2700 (ish) and I run a ROI of 2600x2500 when I image, solar disk is just over 2400 pixels across, not measured it, but is roughly that big...
Minh.
My gear:
Camera:
My gear:
Camera:
