Heads Up 26th July
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Heads Up 26th July
Hi all, the sun finally came out but with high amounts of thin haze. Some nice proms i both HA and CaK, filaments and AR's. Some North polar falculae I think too.
- Screenshot (256).png (637.32 KiB) Viewed 421 times
- Screenshot (259).png (558.07 KiB) Viewed 421 times
- Screenshot (258).png (566.96 KiB) Viewed 421 times
- Screenshot (257).png (970.89 KiB) Viewed 421 times
- Screenshot (266).png (484.23 KiB) Viewed 421 times
- Screenshot (269).png (512.9 KiB) Viewed 421 times
- Screenshot (267).png (442.8 KiB) Viewed 421 times
- Screenshot (268).png (1006.11 KiB) Viewed 421 times
- Screenshot (270).png (998.39 KiB) Viewed 421 times
- Screenshot (272).png (1023.58 KiB) Viewed 421 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Rusted
- Has thanked: 8127 times
- Been thanked: 1943 times
Re: Heads Up 26th July
Thanks.
May I ask whether these equally spaced filaments [at left, on your last image] are a regular occurance?
There have been several sets in the eastern hemisphere recently.
If they were terrestrial clouds we would talk about waves formations.
Does the sun exhibit wave formations over such vast distances?
- Stardust5858
Hi Rusted, I'm no expert by far but there is I think, large solar waves that sweep across the sun associated with the magnetic field being wound up around the sun. I'm not sure about the dynamics of such in association with filaments. Others on here have far more knowledge than I do and I may be completely wrong. Sorry not to be able to give you a definitive answer.Rusted wrote: ↑Mon Jul 26, 2021 2:03 pm Thanks.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Rod, forecast wasn't as good as it is so you can never tell can you. Yes, lots going on.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17970 times
- Been thanked: 8900 times
Great to see!! interesting about the polar faculae, they will soon be disappearing as solar max creeps up, enjoy them while you can
- Stardust5858
Thanks Alexandra, yeah, just noticed the polar faculae in the North polar region before I packed up. I tried to see if there were any in the south polar region but didn't see anything.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20767 times
- Been thanked: 10453 times
Great overview of the day Ella, I just stuck to Ha today.
- Stardust5858
Thanks Mark, great you got a look too.marktownley wrote: ↑Mon Jul 26, 2021 3:57 pm Great overview of the day Ella, I just stuck to Ha today.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Thanks Ella for today's excellent captures of the events.
You are lucky - as with others to capture these today, as here cloudy all day except very late, so am hoping to try some Lunar and Saturn imaging if those approaching clouds don't yet cover here. It could be the first light of the new SkyWatcher ESPRIT 80ED scope, which is now mounted as part of the Tri-scope assembly and just needs aligning with the two SolarScopes...
Cheers for now
Cheers for now
- Has thanked: 8543 times
- Been thanked: 8268 times
Thanks, Ella. A nice crop of images there.
Lovely images Ella, nice to see the screenshots.
Here no chance to imaging, rain ... rain ...
