24.08.2021 AR2859 in veiled seeing.
Rusted
Has thanked: 8114 times
Been thanked: 1941 times
Post by Rusted »
It has been impossible to focus sharply all day. :oops:
24.08.2021 18.16 1.25x 2x gpc 2.jpg (114.3 KiB) Viewed 440 times
Has thanked: 17813 times
Been thanked: 16953 times
Re: 24.08.2021 AR2859 in veiled seeing.
Post by DeepSolar64 »
You still show more detail in AR12859 than I can see visually.
Hughsie
Has thanked: 300 times
Been thanked: 312 times
Post by Hughsie »
Good effort though, you have quite a lot of detail there.
Lunt 60mm DS TH⍺ B1200CPT.
ZWO ASI 174mm & tilt adapter.
SkyWatcher EQ6R-Pro.
SharpCap Pro.
Various Powermates and Barlows.
One cat with a love of tripod legs.
arnedanielsen
Has thanked: 6276 times
Been thanked: 7298 times
Post by arnedanielsen »
Still impressive result despite the challenging conditions!
Thanks for sharing,
Arne
Arne
AstroBin: https://www.astrobin.com/users/arnedani/
AJamesB
Has thanked: 1154 times
Been thanked: 630 times
Post by AJamesB »
Nailing focus is still something I haven't fully come to grips with, especially with it fluctuates so much in variable seeing. I'm convinced at this point there is no 'perfect focus' point, more just a range where its in focus more than it isn't, lol.
Great image though! Ya all are giving me aperature fever with shots like this:)
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
allhoest
Has thanked: 714 times
Been thanked: 496 times
Post by allhoest »
Very contrasted image.
CS
Alex.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Well done on your excellent and difficult-focusing capture Chris.
I had the same problem this morning.
Thanks for sharing
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
Great job with this one Chris: love that delicate lightbridge.
Has thanked: 17925 times
Been thanked: 8894 times
I second what Franco said above, a jolly good image!! :bow :hamster:
Rusted
Post by Rusted »
Thank you everybody! :bow
That light bridge was amazing. Not only thin but crooked.
It gave me something to aim for in pulling something from the mush in ImPPG. :D
Regarding focusing:
Both my iStar refractors [180mm f/12 and 150mm f/10 H-a] are normally exactly in focus or they are not.
When the seeing allows it is shocking how microscopically small are the focuser movements required.
I highly recommend electric focusing to completely avoid touching the telescope.
I use inexpensive, belt driven, Skywatcher DC gearbox motors with HitecAstro [UK] control boxes.
The timing belts work fine on the typically textured focuser knobs. No need to use the slow motion knob.
Tiny movements are available from the HitechAstro software, on screen, using the mouse.
Stepper motors would need toothed sprockets to maintain repeatable positioning.
I cut motor mounting brackets out of black plastic, kitchen cutting boards.
The last two days have been awful! Making me question everything I must be doing wrong.
Others have confirmed that it wasn't just me. It was the western European sky misbehaving. :D
P1470023 rsz.JPG (146.26 KiB) Viewed 385 times
The Jetstream was sat right over you Rusted https://www.netweather.tv/charts-and-data/jetstream
EGRAY_OBSERVATORY
Thanks Alexandra for advising about the Jetstream over Chris, as it is also over me too, which accounts for the very bad stable imaging of yesterday morning..
Rusted
Post by Rusted »
Thank you Alexandra. :bow
The Link has been saved. :D
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Great shot.
Ivan
Been thanked: 4959 times
Post by eroel »
Chris:
Super image in spite of seeing.
Regards.
Rusted
Post by Rusted »
Thank you both. :bow
I keep trying. :D
