Here's my first attempt at catching a sunspot in WL & Ha in the same session... which, in presenting them side by side, gave me the challenge of getting the 'right' yellow & orange colour, and now I'm stuck on some terminology and hoped you could help me understand?
I've heard the terms 'white light' and 'solar continuum' (SC) used interchangeably. I used a solar continuum filter with a Herschel Wedge to catch the 'white light' image and I'm wondering about the correct description. Would the title of the left image be 'AR12859 in WL' or 'AR12859 in SC' or 'AR12859 in WL with a SC filter' or am I just being a fusspot?!
NS 20210823 WL1436 Ha1501 Sun AR2859 by Nic Spencer, on Flickr
White Light or Solar Continuum?
- nicspenceryork
- Has thanked: 6087 times
- Been thanked: 1321 times
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: White Light or Solar Continuum?
Nice imaging and comparison. I use the term white light, although either will do. White light does seem to prevent the confusion you present.
Dan
South central Indiana
USA
USA
Hi Nic,
I would suggest that "AR12859 in WL with a SC-filter on the HW' would certainly and simply explain enough..
If somebody wants to know more, then of course they can easily ask..
Two excellent images and thanks for sharing
- Has thanked: 17855 times
- Been thanked: 17003 times
Technically white light and continuum are the same but if you are using a narrowband 540nm filter it is not continuum but 540nm in the green part of the spectrum. But even though it is really 540nm green, in my posts I still label it “ WL “ because I am using the filter to enhance photospheric features usually seen in white light continuum. And it’s called a “ Continuum “ filter after all.
That’s my two cents worth.
In my observations I usually list the filter if it’s being used. For example, scope, wedge and filter.
Other bands can be used to accent photosphere features too as long as they are not ultra narrowband. Ha filters like those used for deep sky , Gband 430nm filters and K line filters. K line filters are said to do good for faculae. Ultra narrowband K line is of course Ca II K which shows lower chromosphere features.
Simple color filters can be of use too!
- nicspenceryork
Thanks Dan, Terry & James.
I’ll carry on with an overall ‘WL’ title then and list the equipment in the description. The ‘540nm in the green part of the spectrum’ detail helped the penny drop.
Much appreciated,
Much appreciated,
- Been thanked: 8907 times
That is an excellent image, but also an excellent question and made me think. My understanding of continuum is the continuous spectrum. Therefore, the surface of the Sun which emits a continuous spectrum. Therefore, the photosphere emits light across the spectrum and is called the solar continuum. However, the Baader Continuum filter helps you to resolve the granulations of the photosphere (solar continuum) more easily but is however a single wavelength of just 540nm
I need to go and look this up in a book
Montana wrote: ↑Sun Aug 29, 2021 5:19 pm That is an excellent image, but also an excellent question and made me think. My understanding of continuum is the continuous spectrum. Therefore, the surface of the Sun which emits a continuous spectrum. Therefore, the photosphere emits light across the spectrum and is called the solar continuum. However, the Baader Continuum filter helps you to resolve the granulations of the photosphere (solar continuum) more easily but is however a single wavelength of just 540nm
Yep, technically it isn't continuum but 540nm. But....
