I just inspected my B600 and noticed the blue glass has fogged up again. That explains the not so clear image of the Sun on the top left corner!
I've had it replaced before a few years back but I wanted to ask is this something we need to get replaced quite often?
I have been looking up methods on how to clean it but are we better off just replacing it? Only because it's hard to find here and shipping costs literally go through the roof.
Lunt Blue Glass Fogging
- 04Stefan07
- Has thanked: 15 times
- Been thanked: 18 times
SOLAR SCOPES: Lunt LS50THa Pressure Tuned with B600 filter & Moonlite Focuser, Daystar Quark Chromosphere
MOUNTS: Skywatcher HEQ5 Pro & Skywatcher Star Adventurer
CAMERA: Player One Neptune-M & Flea3 1.3 MP Mono USB3
- 04Stefan07
Re: Lunt Blue Glass Fogging
I did some googling and some people used metal polish. I gave it a crack and it worked absolutely beutifully. Back to brand, spanking new.
Is it better to replace the glass or will cleaning it be ok and not cause any damage?
- Been thanked: 16689 times
I hear the Lunt blockers can be cleaned successfully as you have done. Coronado blockers have to be replaced.
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
Any particular metal polish? Outside, inside, or both sides?
My B1200S2 is already "mottled."
- Has thanked: 8415 times
- Been thanked: 8161 times
I’ve used simple lens cleaning fluid and a soft cloth to remove the surface crud off these blue filters, which do seem to fog up from time to time. I’m assuming it’s the same issue that you’re facing.
I clean both surfaces by removing the filters. It’s a bit fiddly with the very small grub screws, but worth the effort.
- Been thanked: 4786 times
- 04Stefan07
I used Autosol Metal Polish which I already had.
The glass looks practically brand new.
I read somewhere that CLR cleaner does well too.
