Sun September 8th 2021_RCT Images
Has thanked: 8523 times
Been thanked: 8252 times
Post by Carbon60 »
I thought I'd give my 250mm RCT a run this morning. The seeing conditions were pretty good, although there were some contrails and a bit of high level variable haze to make it a bit more challenging, as if it isn't challenging enough at these image scales. I'm really pleased with the new etalon housing configuration which is working perfectly with everything aligned and with the etalon really easy to tune.
My focus was the two main ARs 12866 and 12868 which were captured using a 2.5x Powermate and Basler acA1920-155um camera. I used my usual Genika Astro for image capture, AS!3 for stacking, ImPPG for deconvolution/sharpening and PixInsight to refine the final images. My RCT is fitted with a full size Aries ERF (triband) and an internal barlow lens to make the output light cone parallel for the Lunt 35 etalon and refocusing lens. Thanks to Valery for tips on processing. Still a work in progress, but Improving, I think. So much also depends on the conditions, as we know....
Anyhow here are the images.
First up is a mosaic of the two ARs in question:
Image20210908_Ha_AR2866_2868_RCT by Stuart Green, on Flickr
...and the individual images of the two ARs:
Image20210908_Ha_AR2866_RCT by Stuart Green, on Flickr
Image20210908_Ha_AR2868 by Stuart Green, on Flickr
That was it for today and for a little while now we've got some weather coming through with an Amber Warning for thunder storms.
Thanks for looking.
eroel
Been thanked: 4957 times
Re: Sun September 8th 2021_RCT Images
Post by eroel »
Stu:
Super images.
Best wishes.
RodAstro
Has thanked: 286 times
Been thanked: 399 times
Post by RodAstro »
Very nice images Stu
The two regions have been very active all afternoon with some nice bright flares moving through them.
The sun is interesting at last.
Rod
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Wow, what a details Stu.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
rigel123
Has thanked: 8536 times
Been thanked: 8767 times
Post by rigel123 »
Beautiful details in the AR's Stu! I think Valery's tips worked well for you in these images!
Has thanked: 17807 times
Been thanked: 16942 times
Post by DeepSolar64 »
WoW, Stuart. Wonderfully detailed RCT images!!
Has thanked: 20738 times
Been thanked: 10430 times
They're very nice Stu!
Post by Carbon60 »
Many thanks, everyone.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Wow Stu, such excellent images to behold. The RCT is certainly very able and these are just great.
And yes thunder-storms are very likely too.
Thanks for sharing
dhkaiser
Has thanked: 1407 times
Been thanked: 899 times
Post by dhkaiser »
Wonderful details Stu!
Dan
South central Indiana
USA
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Hi Stue,
Some real improvements in your RCT images.
Do you use SS or DS etalon? I believe the DS is the way to go (even with some gain increasing to keep the exposure shorter).
Post by Carbon60 »
Many thanks, Terry, Dan and Valery.
Much appreciated.
Post by Carbon60 »
Valery wrote: Wed Sep 08, 2021 11:29 pm Hi Stue,
Thanks, Valery. I might get around to making this a DS setup sometime, probably by fitting one of my Lunt 60 modules in front of the Lunt 35 with suitable machined adapters.
Anyhow, I've been playing around with the settings in PixInsight (Linear Transform Function which is smart sharpening, and deconvolution). By experimenting with the parameters and the order of the applied enhancement processes I've ended up with a much better result (I believe). The risk, of course, is overplaying it and making the final image look overworked. I think I'm getting there with this hi-res stuff.
Here's the original stacked image from AS!3
Image20210908_AS3_Stacked Image (RCT) by Stuart Green, on Flickr
and here it is processed in PixInsight using combinations of sharpening and deconvolution on the finest scales.
Image20210908_Sharpened_Deconvoluted_ PixInsight by Stuart Green, on Flickr
Compare this with my previous effort on the same image and the difference is clear.
Image20210908_ImPPG_Sharpened_Deconvoluted_ PixInsight Refined by Stuart Green, on Flickr
I'd appreciate your opinion and comments.
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
SUPERB!
Marios S.Ioannou
Sketcher/Visual Observer
Looks like you're getting the processing sussed Stu.
Post by Carbon60 »
marktownley wrote: Thu Sep 09, 2021 7:38 pm Looks like you're getting the processing sussed Stu.
Thanks, Mark….little by little :)
Stu
AJamesB
Has thanked: 1154 times
Been thanked: 630 times
Post by AJamesB »
Carbon60 wrote: Thu Sep 09, 2021 12:16 pm I've been playing around with the settings in PixInsight (Linear Transform Function which is smart sharpening, and deconvolution).
Deconvolution in Pixinsight is my primary sharpening method, but I'd never thought to try linear transform function. I'll have to play around with that. Looking good!
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
