Solar goals?
Has thanked: 17807 times
Been thanked: 16948 times
Solar goals?
Post by DeepSolar64 »
I am curious. What are your solar goals for the upcoming future? It of course can be anything related to solar observing and imaging.
Mine is to observe and document all of Solar Cycle 25 using a combination of my visual observations, GONG and SDO images and images of my own and others. To complete a thorough comprehensive record of Solar Cycle 25 and make it my own!
Has thanked: 20738 times
Been thanked: 10436 times
Re: Solar goals?
Interesting question James!
Certainly in the short term (by next spring) I want to develop the mount for the 'travelling kit' so I can take the 8" HaT out of the city to better seeing conditions to use it to potential - but, this is with caveat that said mounting system needs to be 'boat friendly' in terms of portability. Boat friendly is a step up in size than 'airline friendly'. This new mid scale mount needs to be nighttime friendly for my 4" triplet I have on order which I want to capitalise on the 'darker' night skies of the canal for some moon and planet viewing... I think a second hand eq5 will probably be where I go with this...
After this more tinkering with the CaK setup will follow as the days grow longer next year... I quite fancy dipping into WL imaging and viewing a bit more. For Ha i'm fancying a 6" frac as this is probably my realistic 'use relatively frequently' scope when based at home for 656nm...
Longer term my mind is on the total eclipse in Iceland in 2026, the setup that goes there, how I view / image it... decisions decisions!
Throughout this period I just hope for clear skies when i'm not at work and have free time!
AndiesHandyHandies
Has thanked: 3304 times
Been thanked: 1902 times
Re: Solar goals?
Post by AndiesHandyHandies »
Stop messing with the PST Mod? Get it working with the binoviewers on an Ioptron Alt-Az mount. For comfy, non-rotating, viewing.
Quarks on RuMak 180.
Start drawing visual views.
350mm solar mod.
Image proms.
Cheers. Andrew.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: Solar goals?
Post by EGRAY_OBSERVATORY »
I think you know where I am going James, so whatever happens - will happen.
But Mark, for Iceland, surely you would not consider motoring there with your boat eh !!!!!!!!!!!!!!!!!! He he !
Re: Solar goals?
Mark,
I am considering a 6" frac myself. Probably a Sky-Watcher or Celestron Achromat for white light. A Lunt CaK filter, Celestron AVX mount and a binoviewer is also a possibility sometime in Solar Cycle 25. And then there is a Sodium D line Quark!
Andrew,
Ha Quarks I presume? Have you ever thought of Sodium D Line or Magnesium?
Terry,
Mark could be a modern viking in a LONGboat! :lol:
Has thanked: 8523 times
Been thanked: 8253 times
Re: Solar goals?
Post by Carbon60 »
Good question, James.
I’m going to continue the process of continuous improvement across the spectrum and over a range of image scales. I’m looking forward to some humongous sunspots as cycle 25 develops and to imaging these in CaK, WL and Ha. I’m also looking forward to some powerful CMEs to entertain my magnetometer and further meteor storms for my radio meteor detector. Busy, busy…. :)
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Re: Solar goals?
Post by JochenM »
Short/mid term, trying to get better at pulling images out of the equipment I have (I think I have most bases covered with filters and scopes). Especially CaK is where I feel I can still improve (one step at a time :) ).
Long term, I would like to do some WL/Continuum with my C9.25. But for the time being (with weather/conditions as they are here), I don't think it makes much sense yet just.
Jochen Maes
Belgium
https://www.jochenmaes.com
Re: Solar goals?
Ha ha ha, definitely not going on the boat to Iceland, that will be a flight for sure... Although it is possible to get a Ferry there...
Has thanked: 17924 times
Been thanked: 8889 times
Re: Solar goals?
Great question James :) My goal is still the same as cycle 24, and probably the same for cycle 26 (if I get there)
1. Witness / image an X-class solar flare
2. Image at high res a post flare loop and do an animation
3. Witness and image a white light flare
4. study prominences and features of prominences in more depth
5. Study emerging flux regions in the blue wing at high res and study Ellerman bombs vs arch filament foot points
6. Do more sketching
7. Win Astronomy Photographer of the Year properly and be the first woman to win it
8. Actually understand what all the technical babble means that you lot talk about?
These will all probably never happen (especially the last :lol: ) but you have to aim high :)
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Re: Solar goals?
Post by GreatAttractor »
Short-term (this year):
1. Improve results from the RC8/LS50THa: new camera, better seeing.
2. Capture another flare animation with the RC8/LS50THa.
3. Capture ⩾M-class flare animation with the 90 mm setup.
Long-term:
1. Assemble an intermediate 127-mm class setup for Hα.
2. Travel to an excellent-seeing location with the RC8/LS50THa.
My software:
My images
Radon86
Has thanked: 763 times
Been thanked: 663 times
Re: Solar goals?
Post by Radon86 »
My goals are modest:
Understand the plasma physics of the sun
Understand the magnetic fluxes and field of the sun
Understand solar wind and its generation
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
DavidP
Has thanked: 147 times
Been thanked: 290 times
Re: Solar goals?
Post by DavidP »
I’d like to make my pictures purdier.
rsfoto
Has thanked: 9677 times
Been thanked: 5757 times
Re: Solar goals?
Post by rsfoto »
Hi James,
Cut down my neighbours Palm tree ...
Re: Solar goals?
Wow, everyone. I have really enjoyed reading everyone's goals. All of you have some really good ones!
Mark,
I would love to go to the Faroe Islands! Plane, yes!
Alexandra,
I really like your X-Class/White light flare goal. But that one can be dangerous. Think " Carrington Event "!!
Rainer,
I really laughed hard when reading yours!
Keep em' coming!!
AndiesHandyHandies
Re: Solar goals?
DeepSolar64 wrote: Fri Sep 10, 2021 4:41 am
Andrew,
Still working on H-alpha.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Re: Solar goals?
Post by MAURITS »
My goal is to learn something about the sun on the kids in the classroom, I have made a PowerPoint presentation with lots of images and creative things ...
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Re: Solar goals?
Maurits,
Passing on the knowledge and skills of solar astronomy to future amateur and professional astronomers. That’s an awesome goal!!
Hughsie
Has thanked: 300 times
Been thanked: 312 times
Re: Solar goals?
Post by Hughsie »
Hi James,
Two goals for me;
1) More consistency when setting up/imaging with the double stack I have recently acquired. It’s a faff at the moment and I know it should be less hard work getting it tuned.
2) Find a remote site to image the Sun from. I live at the bottom of a hill and even now I have limited observing/imaging time due to obstructions.
Good question btw.
John
Lunt 60mm DS TH⍺ B1200CPT.
ZWO ASI 174mm & tilt adapter.
SkyWatcher EQ6R-Pro.
SharpCap Pro.
Various Powermates and Barlows.
One cat with a love of tripod legs.
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Re: Solar goals?
Post by Ivan »
My goal for a year or a year and a half is the Lunt60 and a new camera. I also want to learn how to shoot and edit photos with my new mod. I also think about DS 90mm for him. In general, all my thoughts are about the equipment.
In the long term, of course, I would like to find my place among colleagues in our hobby, I want more knowledge and experience. I would like to shoot cool FD in high resolution, learn how to make animations.
I support Alexandra in her quest to understand the technical aspects of our hobby: optics and electronics. Although I understand that my own knowledge is insignificant in comparison with her knowledge and experience. I would even venture to suggest creating something like, a new topic, where the most experienced of us in an accessible language would explain the basics of our hobby starting from the very basics.
Ivan
Re: Solar goals?
John and Ivan, You have awesome goals! Ivan, I agree with you on finding your place among the colleagues in our hobby. I have learned that I can learn more from within a group than I can on my own.
