New camera ASI174mm - NR problem solved and Sun WL and HA Sept 2021
Radon86
Has thanked: 763 times
Been thanked: 663 times
Post by Radon86 »
Hi All on SolarChatForum,
I have been away from the SCF, but recently managed a few imaging sessions with my new ASI 174mm camera and HEQ5 Pro mount and also 90mm refractor which I am still testing.
Anyhow, I got some WL images with my ED70 refractor and H-Alpha with the Quark Chromosphere. Here are some images, minimal processing done.
1) Sun WL 20210907 - ASI120mm-S; 2 images merged for multiple sunspots
2) Sun spots 20210908 H-alpha- ASI120mm-S - flats applied, ImageJ to remove newton rings; ImPPG
3) Sun : 20210908- ASI174mm - flats with Newton rings
4) Sun : 20210908: ASI174mm - H-alpha, ZWO tilt adaptor, 2mm tilt (or 2.86 degrees) removes NR
Happy imaging, clear skies to all !
Magnus
ASI120mm-Inverse FFT of 10_59_01_g5_ap3405-ImageJ-ImPPG-Sig135UM15.jpg (175.76 KiB) Viewed 347 times
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: New camera ASI174mm - NR problem solved and Sun WL and HA Sept 2021
Post by EGRAY_OBSERVATORY »
You are getting there Magnus.
The last image (possibly with a little more fine-focusing using the limb-edge) is looking good, so keep up the good work...
Radon86
Post by Radon86 »
Thanks Terry,
I will take another look next time when there is good seeing to see if my focus can be improved; hopefully the tilt will not blur the image too much.
Magnus
Has thanked: 17925 times
Been thanked: 8894 times
Super images :bow :hamster:
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Wonderful images.
Marios S.Ioannou
Sketcher/Visual Observer
Has thanked: 20756 times
Been thanked: 10441 times
Good results Magnus!
arnedanielsen
Has thanked: 6276 times
Been thanked: 7295 times
Post by arnedanielsen »
Looks good, Magnus!
Thanks for sharing,
Arne
Arne
Radon86
Post by Radon86 »
Hi All,
Thank you so much, Alexandra,Arne,Mark and Terry for your kind comments.
Its taken over 2 years to learn the solar imaging, and I think I am getting the hang of it now.
Need to work more on my processing (have to take patience to take each step carefully, follow a routine or formula).
Many thanks for everyone for their support and encouragement.
Magnus
