Which of these Sodium images do you prefer ?
Please let me know which of these two Sodium images you prefer ? Thanks vm
Included is the grey-scale capture after stacking 75% of a 100-frame capture and otherwise unprocessed - all of the same capture.
- 09_33_35_AS_P75_lapl2_ap3.jpg (14.37 KiB) Viewed 481 times
- A. 09_33_35_AS_P75_lapl2_ap3.jpg (33.09 KiB) Viewed 481 times
- B. 8-9-2021 0833z SODIUM AR2866, 2868 & 2869.jpg (33.37 KiB) Viewed 481 times
- Has thanked: 9723 times
- Been thanked: 5773 times
Re: Which of these Sodium images do you prefer ?
Hi Terry,
Version A as version B is over sharpened and has to many artifacts ...
Thank you Rainer and Alexandra.
Certainly with the Sodium captures, IMPPG does nothing useful to improve the stack and the un-processed grey-scale image.
I can't understand why the term "sharpening" is being used in the IMPPG manual, as adding these artefacts is doing the opposite thing.
Even after varying the settings, nothing useful seems to result.
Whereas in PaintShopPro, various stages of sharpening etc., are easily available and image "A" is done using that method...
If somebody-else wants to extract from the grey-scale image and try for a better IMPPG result, but not to use Photoshop at all, as I don't have that at all...
Thanks in advance
Thanks in advance
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Hello Terry,
Version A please.
Version A please.
Marios S.Ioannou
Sketcher/Visual Observer
Thanks Marious and I agree too, but still more work to improve the Sodium side of imaging in four lights.
- Has thanked: 17853 times
- Been thanked: 16992 times
Certainly image A.
- Been thanked: 4980 times
Thank you Eric for your opinion - which with other is quite important for future Sodium imaging.
You also have a good weekend too.
- Has thanked: 9319 times
- Been thanked: 6157 times
- Has thanked: 20813 times
- Been thanked: 10487 times
Hi Terry.
Version A in this instance. Like others have said B is oversharpened.
Post some screen grabs of the settings you're using in ImPPG for sharpening. My money is on the sharpening radius being too high.
The other thing I would say is the seeing was bad or the focus was slightly off maybe looking at the b&w image?
