Belated August Ca K image / 8/29 & 30
- Been thanked: 2713 times
Dear All,
I am running out of time with too many things to do ...Here are some Ca K images taken at the end of August.
This one image was taken on August 29 with a double stack Ca K filter. Note the small flare in the sunspot group :
http://astrosurf.com/viladrich/astro/so ... Alluxa.jpg
One day later, with a simple stack Ca K (which explains the reduction of contrast) :
http://astrosurf.com/viladrich/astro/so ... SI1600.jpg
And a zoom at the small group :
http://astrosurf.com/viladrich/astro/so ... ASI290.jpg
Clear skies
Clear skies
- Has thanked: 8418 times
- Been thanked: 8162 times
Re: Belated August Ca K image / 8/29 & 30
Excellent images, Christian, especially the close view. Lots of lovely detail.
- Has thanked: 6181 times
- Been thanked: 7142 times
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
SUPERB!
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 20437 times
- Been thanked: 10245 times
Excellent Christian, the difference with double stack is really quite apparent.
- Been thanked: 8791 times
Wow!!! what a joy to view I like the use of tilting sun too, I should use it more
- Has thanked: 1305 times
- Been thanked: 63 times
Beautiful FDs clearly showing the advantage of using a DS. Superb Hi Res of AR 2860 with great seeing.
John
John
- Has thanked: 1262 times
- Been thanked: 1057 times
The only perfectly tuned setup and fantastic output of the processing, that is worth repeating and trying out
What could be a comparison with the 183 camera for both cases, FD in full resolution instead of the 1600 and cropped one vs the 290 for close-up?
regards
Leo
regards
Leo
Thanks to all :-)
Leo,here the ASI 290 runs at 166 frames/s. So, I would say it would take the lead on the ASI183. But this is just my guess.
Well, you're right, crop on the 183 chip with the same resolution gives only 80fps, i.e. half as much compared to full frame of 290
thanks
Leo
thanks
Leo
- Been thanked: 4786 times
I really like my 290mm for CaK, it is my goto camera for anything other than full disk at 393nm.
