FDs and prom animations 15th Sept 2021
Has thanked: 8523 times
Been thanked: 8259 times
Post by Carbon60 »
A beautiful morning after some early morning mist/fog lifted and an opportunity to make a couple of short prom animations. Things are really quiet and even the proms showed little movement over 15-20 minute timespans.
First up the FDs in CaK and Ha.
Image20210915_CaK_FD_Mono by Stuart Green, on Flickr
Image20210915_CaK_FD_Colour by Stuart Green, on Flickr
Ha mosaic with a few 'witness' lines along some of the joins :roll: :roll:
Image20210915_Ha_FD_Mono by Stuart Green, on Flickr
Image20210915_Ha_FD_Colour by Stuart Green, on Flickr
Animated small prom and departing active region.
Image20210915_Ha_Prom_Animation_aligned by Stuart Green, on Flickr
...and a little prom forest with some subtle movements close to the limb.
Image20210915_Ha_Prom2_Animation_Aligned by Stuart Green, on Flickr
Image20210915_Ha_White Proms_Mono by Stuart Green, on Flickr
Image20210915_Ha_White Proms_Colour by Stuart Green, on Flickr
In addition, here's a three pane mosaic of a random piece of the chromosphere.
Image20210915_Ha_Chromosphere_Mono by Stuart Green, on Flickr
Thanks for looking.
AJamesB
Has thanked: 1154 times
Been thanked: 630 times
Re: FDs and prom animations 15th Sept 2021
Post by AJamesB »
Beautiful hi-res work, love it!
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
A great job with the excellent images and animations and at least makes up for just the one AR.
Thanks Stu.
DavidP
Has thanked: 147 times
Been thanked: 291 times
Post by DavidP »
Stuart.
Your last 3 images are stunning. The mosaic is just so rich detailed and shows a subtle hand at bringing out contrast. Your processing of the Ha images of the proms is fantastic. Any words of advice on how you achieve your jet black background and gorgeous luminescence of the prominences ?
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
WoW, Stuart. You are an ace at this imaging stuff. All of these are so good it's hard to pick a favorite. You certainly had the sun well documented today and did it beautifully.
Three thumbs up!!! WooHoo!!!
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
I like the prom Images Stu.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Radon86
Has thanked: 763 times
Been thanked: 663 times
Post by Radon86 »
Hi Stuart (Carbon60),
Outstanding work Stuart !
:hamster:
How did you align the images ? DId you use ImPPG ? I would be grateful if you could point me to a tutorial on aligning images for Prom animations ?
Many thanks.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Has thanked: 17925 times
Been thanked: 8894 times
Wow!! what a set Stuart :bow :hamster: I love the hedgerow prom :) looks like we are just about to lose all the great activity though.
Post by Carbon60 »
DavidP wrote: Thu Sep 16, 2021 2:21 am Stuart.
Hi David,
This is a combination image (proms and disk processed separately). This allows the proms to be processed so that they 'pop' by boosting the contrast.
Post by Carbon60 »
Boso36 wrote: Thu Sep 16, 2021 9:29 am Hi Stuart (Carbon60),
:hamster:
Many thanks.
Magnus
Hi Magnus,
I use ImPPG to align the images. If you head to the library section you'll see some tutorials on how to make animations, including one from me.
viewtopic.php?f=7&t=28572
I hope this helps.
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Excellent work!
Marios S.Ioannou
Sketcher/Visual Observer
Has thanked: 20757 times
Been thanked: 10444 times
Looking good Stu! I was thinking you would be imaging when the sun was out earlier...
arnedanielsen
Has thanked: 6276 times
Been thanked: 7298 times
Post by arnedanielsen »
Excellent work, Stu. I love them all!
Arne
Arne
rigel123
Has thanked: 8547 times
Been thanked: 8781 times
Post by rigel123 »
Excellent Stu, the images and animations are top notch!
Post by Carbon60 »
Many thanks, Arne and Warren.
Stu
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
Looking great, Stu.
Post by Carbon60 »
Many thanks, Franco.
