MiniSHG and CaK Solar 16th Sept 2021
- Has thanked: 174 times
- Been thanked: 619 times
The MiniSHG is giving some good results.
The current data is from 9 sec scans (in Declination) and processed in EN_INTI software (about 3 sec per image!!!!)
The first image is a typical scan result - no additional processing. The scan also provides a Prominence image - neat!!
This is a stack (AS3!) of four 9sec scan images I think the results are very good and would certainly be improved with a larger stack.
The current CaK status is pretty quiet. The AR is just leaving the building! (I will do some comparison images between the MiniSHG and the CaK DIY filter. I have a feeling that the MiniSHG might win!!)
Re: MiniSHG and CaK Solar 16th Sept 2021
You can also select different wavelengths by a pixel offset.
This shows the results in the red wing at +0.4A
- Has thanked: 17813 times
- Been thanked: 16953 times
it's unusual to see Ca II K so quiet.
Yeah, very quiet. I haven't seen it like this for a while.
- Has thanked: 17925 times
- Been thanked: 8894 times
Wow!! amazing images do you have a photo of the miniSHG?
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Beautiful images!
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 20757 times
- Been thanked: 10442 times
Very good Ken!
Alexandra,
The MiniSHG uses two 120mm FL lenses from Surplus Shed, a 2400 l/mm grating, a 20 micron slit gap (Ex my Spectra-L200) and the ASI 178 camera.
The MiniSHG fits the hand and weighs just over 1Kg. For comparison here's an SHG I built only five years ago over 1 mtr length and over 11Kg weight. Times have changed!!
The "CaK with DIY filter 091840.jpg" is my favourite Ken and interesting set-up's
Thanks for sharing
Thanks for sharing
Ken,
I think you miniaturized this time around!
Terry,
Thanks mate.
It looks even better at full resolution.
James,
This is certainly the way forward for SHG.
The advent of high speed, small pixel Cmos cameras, combined with very narrow slit gaps (10 micron) has definitely changed our ideas.
As I said in the Preface to my book "Imaging Sunlight" in 2016:
""....it's just a matter of time before the software matures to further refine the images and show the full potential, at any chosen wavelength, of the digital SHG""
9 sec scans and 3 sec processing to a detailed image
It's time has come!!!!
Thanks mate.
James,
WOW!!! it is soon getting to a point even a dumb person like me may be able to have one
Alexandra,
I don't think for one moment you're "dumb"!!!
Yes, I'm pretty sure the MiniSHG (or similar) will be commercialised in the near future.
It's compact design is pretty robust and flexible enough to be used on most refractors.
Operation is very simple focus the spectrum, focus on the solar edge and then the final tweak to fine focus on the "wiggles" inside the absorption line. Majic!!!
- Has thanked: 8523 times
- Been thanked: 8259 times
Excellent, Ken. Certainly is nice and compact.
Bang per wavelength buck this is definitely the way to go.
Where else would you find a 0.2A resolution filter for CaK H alpha and every wavelengths between for less than $700 ??????
I can supply a detailed parts list of all the components needed to assemble a MiniSHG.
Drop me a PM or email for details.
- galaxie427
- Oh, I get it now!
- Has thanked: 193 times
- Been thanked: 16 times
Just admiring your wonderful results. Your project sent me back in time to a good place, Astronomy 101 and our slit spectrometer project, Merlin....Thank you!
