90mm Triplet F6.7 Baader Luminance UV-IR 4.2x Chromo Clave' 25mm 2520mm fl 101x
LG 1.00 is Learmonth Gong
9.15 BST Clouds with gaps Light wind Over houses
Spiricules clearly seen
6.30 Hollow pyramid LG 6.30
To right sunspot group.
A little stubby dovetail prom
5.30 Four vertical proms LG 8.30
8.00 Two small proms
10.00 Faint spray
11.30 Little hollow pyramid
12.00 Horizontal bright line source on right
3.00 Diamond prom with connection to seperated pillar prom below LG 10.30
I could see the large filament under LG 12.00
Cheers. Andrew.
90mm Triplet with 4.2x barlow and Quark Chromo
- Has thanked: 3317 times
- Been thanked: 1907 times
Re: 90mm Triplet with 4.2x barlow and Quark Chromo
Lost all but the larger two proms later when it warmed up.
Similar in the Prom Quark and Mak180 PST Mod. But the PST Mod showed the third on the other side of the sunspot group from the hollow pyramid.
With the bino-viewers the PST Mod is best on the surface. Up to 86x with 12x PZO's.
Cheers. Andrew/
Cheers. Andrew/
Last edited by AndiesHandyHandies on Mon Sep 20, 2021 1:27 pm, edited 1 time in total.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Very good!
Marios S.Ioannou
Sketcher/Visual Observer
Sounds like some good proms today, thanks Andy
No wonder I could see less proms as the day went on. Only the hollow pyramid by the spot group left now.
Cheers. Andrew.
Cheers. Andrew.
- Has thanked: 20813 times
- Been thanked: 10487 times
Good report, I thought you would be out observing today.
