Sun from September 19
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Hello everyone,
Several unpublished images from September 19. Seeing is bad. Photographed with mod Lunt50 + Barlow lens 2x , my daughter helped me set up the equipment
Thanks for watching this.
Ivan
Ivan
- surface inv_color.jpg (349.58 KiB) Viewed 368 times
- surface inv_gray.jpg (336.35 KiB) Viewed 368 times
- assistant.jpg (134.95 KiB) Viewed 368 times
- Has thanked: 9144 times
- Been thanked: 6025 times
Re: Sun from September 19
These are really good, Ivan: you could have not done them without your assistant ! It is great you get your daughter involved.
- Ivan
Thank you Franco.
She helps a lot usually too persistently I gave her an old photo tripod, she calls it her mount
Ivan
- Has thanked: 17667 times
- Been thanked: 8789 times
oooh sounds like you have a little astronomer in the making
Great shots Ivan
Great shots Ivan
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
- Ivan
- Has thanked: 8415 times
- Been thanked: 8161 times
She's done a great job, Ivan. I hope you watched and learned
- Been thanked: 4900 times
Hello Ivan, good to see that your daughter is involved as your assistant.
Thanks for sharing your images and photo.
- Has thanked: 20435 times
- Been thanked: 10244 times
Cool! The assistant takes good pictures!
- Ivan
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
Beautiful capture, Ivan!
Looks like the assistant is in good control of everything!
Arne
Arne
- Ivan
