The sky was predicted to be cloudy but there was clearing albeit with hazy clouds. I concentrated on active regions
and an intriguing filament for this session before the haze gave the view a washed out appearance. It was a great improvement over the previous day when I practiced setting up and putting things away and little else.
Lou
The set up used was comprised of:
180mm ERF on a 180mm Mak + 6nm Halpha filter from Astronomik + Quark Combo + tilter + either a ASI290 or Blackfly 3.2 Mp
This gave the Quark an f15 beam at 2700mm.
ARs and filament from Sept 27
- Been thanked: 1735 times
- rigel123
- Has thanked: 8555 times
- Been thanked: 8783 times
Re: ARs and filament from Sept 27
Wonderful shots Lou!
- Been thanked: 4409 times
Excellent images Lou...that scope/filter combinations works nicely
Excellent shots (uninverted)!
Your Quark crying for a F/40 ratio. Give what it need and the results will impress you even more.
And don't forget the 0.5x reducer after Quark.
- Has thanked: 2463 times
- Been thanked: 4879 times
- Has thanked: 17925 times
- Been thanked: 8895 times
Superb images! the filament looks like a strange insect you made me chuckle when you described the previous day practice setting up and packing away. I have had so many of these practices
- Has thanked: 20757 times
- Been thanked: 10445 times
Very nice images there Lou!
Purrrrfect images Lou - showing so much f9ine detail.
Thanks for sharing
Thanks for sharing
