09.28.21 Sun in Lunt50 mod
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Hello everyone,
After an almost two week break, we had a fairly clear day. I continued to test my mod and experiment with processing. I used colors similar to those used by Pedro, I hope the master will not mind.
The last four sessions were mediocre due to poor seeing and I was not happy with the result, but this time it was much better. All photos were taken using a 2x Barlow lens.
I have fulfilled my old dream to assemble a large-scale mosaic. I assembled it from 10 fragments. The visibility of course changed in the process, but I am quite happy with the result.
I also shot several ARs at approximately 1.5 hour intervals and there are some changes visible.
Thanks for watching this. I will continue to appreciate your criticism and comments. Full resolution FDs is available if you open the picture in a new tab and enlarge.
Ivan
Ibbo
Has thanked: 2443 times
Been thanked: 1650 times
Re: 09.28.21 Sun in Lunt50 mod
Post by Ibbo »
Nice shots.
I used to do full disc mosaics so I remember the varing results across the disc and the missing bits due to cloud.
Good luck with them.
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
Pedro may be the master but you are quite good in your own right. All of these look really good. None of my disc images even come close.
And yes, your first two images do resemble Pedro's!
Two thumbs up my friend!
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
These are excellent Ivan, sharp and detailed. Well done !
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
Indeed Ivan, nice and sharp captured.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
As the already comments Ivan, you have done very well to show us your own efforts.
Thanks for sharing
arnedanielsen
Has thanked: 6276 times
Been thanked: 7298 times
Post by arnedanielsen »
Beautiful collection of images, Ivan!
Great work!
Arne
Arne
Radon86
Has thanked: 763 times
Been thanked: 663 times
Post by Radon86 »
Very nice images Ivan !
But please can you clarify your optical image system, as I am not sure what a Lunt50 mod is. Is it a 50mm blocking filter from Lunt ?
What ERF/telescope was it ??
Looks like a 120mm telescope to me !!!!!
Thanks.
Magnus.
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Has thanked: 17925 times
Been thanked: 8894 times
When opened in full resolution the detail is spectacular, nice work Ivan :bow :hamster:
Ivan
Post by Ivan »
Friends, thank you very much for your kind words, the feedback from hobby colleagues is very important and highly motivating, thanks again.
Ivan
Ivan
Post by Ivan »
Boso36 wrote: Thu Sep 30, 2021 1:44 pm Very nice images Ivan !
Thanks.
Magnus.
Magnus, thanks for your feedback.
My telescope has a 90mm aperture, but I used a Barlow × 2 lens.
Mod (modification) is the connection of the etalon and the blocking filter with a suitable night telescope. In my case, these are Lunt50 and William Optics Megrez 90.
You can read in more detail and competently in this section, all possible modifications are described here: viewforum.php?f=9
Filip's advice and a description of his mod helped me build my mod:
viewtopic.php?f=9&t=19238
Ivan
Has thanked: 20757 times
Been thanked: 10444 times
You got a good run of images there Ivan!
Ivan
Post by Ivan »
marktownley wrote: Thu Sep 30, 2021 7:48 pm You got a good run of images there Ivan!
Thanks Mark, I appreciate your opinion.
Ivan
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Wonderful images!
Marios S.Ioannou
Sketcher/Visual Observer
