Managed to grab one set of 2K frames on AR2882 before the clouds rolled in.
Quite nice to compare the Ha with WL versions of this AR (wish I'd been able to get some WL but the weather wasn't playing nice).
ED80 + Quark
AR2882 in Ha
- Rob63
- Has thanked: 573 times
- Been thanked: 591 times
AR2882 in Ha
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
- Has thanked: 2412 times
- Been thanked: 4787 times
- Has thanked: 17581 times
- Been thanked: 16697 times
Re: AR2882 in Ha
Your image shows nice detail around the spot!
- Been thanked: 8793 times
- Been thanked: 4340 times
Re: AR2882 in Ha
Very nice to see your image of the AR Rob...well done
- Has thanked: 20442 times
- Been thanked: 10248 times
Re: AR2882 in Ha
That's a good capture Rob! I like using the ED80 and quark, it's a good combo.
- Rob63
Re: AR2882 in Ha
I agree Mark, all to often I use the 120mm without really thinking about it, I should use the ED80 more.marktownley wrote: ↑Thu Oct 07, 2021 5:30 am That's a good capture Rob! I like using the ED80 and quark, it's a good combo.
With the less that ideal seeing we get, the 80mm seems to be a great match for the quark and ASI174MM (resolution of 0.48" per pixel and pix size 5.86µm).
