AR2882 in Ha
Rob63
Has thanked: 573 times
Been thanked: 591 times
AR2882 in Ha
Post by Rob63 »
Managed to grab one set of 2K frames on AR2882 before the clouds rolled in.
Quite nice to compare the Ha with WL versions of this AR (wish I'd been able to get some WL but the weather wasn't playing nice).
ED80 + Quark
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
MAURITS
Has thanked: 2412 times
Been thanked: 4787 times
Re: AR2882 in Ha
Post by MAURITS »
Nice to see this region Rob.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 17572 times
Been thanked: 16694 times
Re: AR2882 in Ha
Post by DeepSolar64 »
Your image shows nice detail around the spot!
Has thanked: 17672 times
Been thanked: 8791 times
Re: AR2882 in Ha
Wow!! that's a beauty! :bow :hamster:
Has thanked: 64 times
Been thanked: 4340 times
Re: AR2882 in Ha
Post by MapleRidge »
Very nice to see your image of the AR Rob...well done :bow
Has thanked: 20442 times
Been thanked: 10247 times
Re: AR2882 in Ha
That's a good capture Rob! I like using the ED80 and quark, it's a good combo.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: AR2882 in Ha
Post by EGRAY_OBSERVATORY »
Thanks Rob for your excellent capture of AR2882
Rob63
Re: AR2882 in Ha
Post by Rob63 »
marktownley wrote: Thu Oct 07, 2021 5:30 am That's a good capture Rob! I like using the ED80 and quark, it's a good combo.
I agree Mark, all to often I use the 120mm without really thinking about it, I should use the ED80 more.
With the less that ideal seeing we get, the 80mm seems to be a great match for the quark and ASI174MM (resolution of 0.48" per pixel and pix size 5.86µm).
