8.10.2021 AR2882 through cloud and trees.
Rusted
Has thanked: 8114 times
Been thanked: 1941 times
Post by Rusted »
Cloud, trees, PST etalon woes.. Ignore it if you can. :D
The first image is though cloud. The second though a fork in the trees.
Ellerman bombs suggest I'm not even on-band for H-a. :roll:
Watched a rapid incursion into the umbra from the SE.
The large filament north of the AR is highly mobile and rotating anticlockwise.
8.10.2021 16.35 1.25x 2x gpcs.jpg (140.68 KiB) Viewed 497 times
8.10.2021 16.54 1.25x 2x gpcs.jpg (147.78 KiB) Viewed 497 times
eroel
Been thanked: 4957 times
Re: 8.10.2021 AR2882 through cloud and trees.
Post by eroel »
Chris:
Well you got nice images anyway.
Have a nice and sunny weekend.
Has thanked: 17808 times
Been thanked: 16948 times
Post by DeepSolar64 »
I think they look fine Chris. You did well despite your challenges.
Rusted
Post by Rusted »
Thank you. :bow
Your encouragement makes it all worthwhile. :D
Has thanked: 17924 times
Been thanked: 8890 times
WOW!! right up its nose :hamster: :bow :bow (remember that dark black umbra through, there must be some detail in it :) )
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Challenging conditions, Chris. Nice captures.
Stu
arnedanielsen
Has thanked: 6276 times
Been thanked: 7294 times
Post by arnedanielsen »
Great high-res images, Chris.
Arne
Arne
p1taylor
Has thanked: 1 time
Been thanked: 219 times
Post by p1taylor »
Great images, Chris.
peter
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Excellent close-up of this monster-spot Chris and highly likely flares have and will occur...
Thanks for sharing
Rusted
Post by Rusted »
Thank you everybody. :bow
To Alexandra:
Shadow only has value where substance has fled. ;)
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Thanks for sharing Chris, the images looks very good despite the conditions.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 9292 times
Been thanked: 6127 times
Post by ffellah »
Chris: good work giving the conditions !
Rob63
Has thanked: 593 times
Been thanked: 614 times
Post by Rob63 »
NIce report and really good images despite the conditions.
Rob.
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
Radon86
Has thanked: 763 times
Been thanked: 663 times
Post by Radon86 »
Hello Rusted,
I don't know how you image in those conditions. Is that a black hole in the centre ?
What is your imaging scale ? Are you usng a 150mm refractor ??
Your imaging system looks super complex, how did you work it out ?
Thanks
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Rusted
Post by Rusted »
Thank you all for your kind words. :bow
Magnus:
My full H-alpha set-up is listed in my signature:
It is a basic PST mod. Using a Baader, full aperture 160mm D-ERF to reduce the heat load on the system.
iStar 150mm f/10 H-alpha objective in home made, steel tube.
Baader 2" 35nM & KG3 protective filters on 2" extensions ahead of the FT2535 focuser.
PST etalon in AOK Swiss adapters. Baader 1.25x GPC tight against the back of the etalon.
Not in front where it would alter the f/ratio. The PST etalon needs to see an f/10 light cone.
Lunt S1200S2 straight through, blocking filter rather than an elbow.
One of three T-S GPCs on the camera nose. Power chosen to match the seeing conditions.
The popular ZWO ASI174MM USB3 mono camera. Internal SSDs storage in an i7 laptop.
I monitor the camera on a 27" hi-res AOC monitor.
This provides a very large, square, viewing panel of the hugely magnified, sun's surface in SharpCap as seen by the camera.
I usually get over 100fps at 10ms with a 912x912 frame size.
The greatest weakness in my system is the PST etalon.
While it provides highly detailed images, in good seeing, it suffers from a ring-shaped, sweet spot.
This causes a band of better detail across the frame. With brighter, less detailed corners.
So I fiddle constantly with the etalon tuning and tilt.
I work in comfort at my computer desk, in my home made, raised dome. With a very large, home made, equatorial mounting.
Spending many hours imaging whenever the sun is shining. They say practice makes perfect. So I practice endlessly. ;)
I owe everything to my fellow solar telescope modifiers, observers and imagers.
For their shining examples, guidance in methods, software and equipment choice within my budget.
They have saved me years in desperately trying to catch up with their amazing skills. :bow
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Great shots, Chris. They show that there are no barriers for real hobby, real passion!
Ivan
Radon86
Post by Radon86 »
Rusted wrote: Sat Oct 09, 2021 4:12 pm Thank you all for your kind words. :bow
Thanks Rusted for all the technical info. I will analyse it later !!
:band
All the best,
Magnus
Has thanked: 20738 times
Been thanked: 10436 times
Good looking shots here Chris!
