Seeing on Saturday was medium to poor, but I managed to get something usable out of the RC8/Lunt 50 setup:
It was also the debut of my new Blackfly S BFS-U3-16S2M-CS.I had some residual Newton's rings at the outer FOV, but they didn't interfere with stacking (here I cut most of those parts out). I may need a bit longer screws for the tilter; also, the required tilt changes between telescopes unfortunately. And with the tilter set for RC8, I'm out of backfocus with the 90 mm setup, so I may need to temporarily revert back to the (short) non-rotating Borg helical focuser, until I can shave off a few mm around the Feather Touch. So, for the material below I used the Chameleon 3/ICX445.
After the morning M-class flare (during my breakfast, I was just browsing GONG and saw it), not much happened in AR2822. Just the usual rising/falling of small spikes, and a small surge in the upper FOV (90 mm aperture, 30-second intervals, 1:49 h total):
Minor activity in AR2822 (animation)
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 753 times
- Has thanked: 9144 times
- Been thanked: 6025 times
Re: Minor activity in AR2822 (animation)
A beautiful set and very good animation showing the activity, Great Attractor
Franco.
Franco.
- Has thanked: 6181 times
- Been thanked: 7142 times
- Been thanked: 4786 times
- Has thanked: 17666 times
- Been thanked: 8787 times
Lovely images Filip lots going on in the plage area but none in the spot itself.
Hi Filip, the animation shows well the current activity of the AR2882 complex.
Thanks for sharing
Thanks for sharing
- Has thanked: 20424 times
- Been thanked: 10243 times
Great results Filip!
