Sun FD in H-Alpha and CaK 15th of October 2021
arnedanielsen
Has thanked: 6276 times
Been thanked: 7289 times
Post by arnedanielsen »
Dear friends,
Todays FD images of the Sun in H-Alpha and CaK.
FD image in H-Alpha using a Coronado 60mm/BF15 w/Beloptik ITF, stopped down to 50mm, Baader 35nm H-Alpha and ASI 178mm mounted on a Celestron NexStar SE mount.
Sun60FD_092504_Ha_20211015_ZWO ASI178MM(53096324)_lapl4_ap3677_out_Contrast_resize.jpg
Sun60FD_092504_Ha_20211015_ZWO ASI178MM(53096324)_lapl4_ap3677_out_Contrast_resize.jpg (344.51 KiB) Viewed 319 times
Sun FD in H-Alpha 15th of October 2021
Sun60FD_092504_Ha_20211015_ZWO ASI178MM(53096324)_lapl4_ap3677_out_Contrast_Colorized_resize.jpg
Sun60FD_092504_Ha_20211015_ZWO ASI178MM(53096324)_lapl4_ap3677_out_Contrast_Colorized_resize.jpg (374.35 KiB) Viewed 319 times
Sun FD in H-Alpha 15th of October 2021 - Colorized
FD image in CaK using a William Optics ZenithStar 61II, stopped down to 46mm, Lunt CaK 1200 module, Coronado 2x CeMax and ASI 183mm camera mounted on a SkyWatcher SolarQuest.
SunCaK60_083549_CaK_(3934nm)_20211015_ZWO ASI183MM_lapl4_ap7367_out_Contrast_resize.jpg
SunCaK60_083549_CaK_(3934nm)_20211015_ZWO ASI183MM_lapl4_ap7367_out_Contrast_resize.jpg (233.58 KiB) Viewed 319 times
Sun FD in CaK 15th of October 2021
SunCaK60_083549_CaK_(3934nm)_20211015_ZWO ASI183MM_lapl4_ap7367_out_Contrast_Colorized_resize.jpg
SunCaK60_083549_CaK_(3934nm)_20211015_ZWO ASI183MM_lapl4_ap7367_out_Contrast_Colorized_resize.jpg (251.16 KiB) Viewed 319 times
Sun FD in CaK 15th of October 2021 - Colorized
Click on links to view full size images.
Thanks for looking and best regards,
Arne
Arne
Has thanked: 17807 times
Been thanked: 16942 times
Re: Sun FD in H-Alpha and CaK 15th of October 2021
Post by DeepSolar64 »
These are excellent processed full discs, Arne! I think the sun is calming down a bit.
Has thanked: 64 times
Been thanked: 4406 times
Post by MapleRidge »
Very sharp images Arne...thanks for sharing them :bow
Has thanked: 8523 times
Been thanked: 8252 times
Post by Carbon60 »
Beautiful FDs, Arne.
arnedanielsen
Thank you very much James, Brian and Stu!
James: Yeah, the Sun is turning almost blank. Hope there will be some new AR shortly.
Arne
Arne
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Beautiful FD'S Arne.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
arnedanielsen
Thank you very much, Maurits.
Best regard,
Arne
Arne
Has thanked: 20738 times
Been thanked: 10429 times
Great disks as ever Arne!
arnedanielsen
Thank you very much Mark. Much appreciated.
Arne
Arne
