Heya,
We went from a rather quiet disc with AR2886 just transiting without much activity in its region, then AR2887 came along, blasting, and whatever is trailing it is blasting even more! The eastern limb exploded with a flare, and lots of big surging proms blasted off, perhaps a CME with quite a good chunk of chromosphere going with it. I saw it visually and grabbed a little data on it. Somewhere between 16:00 and 17:00 Eastern time (Florida). Then the sun was too low to see anymore for me over the obs walls. Seeing was pretty good for a late day in my fall, it hovered an arc-second or so. I graphed it to share. I was able to get some fairly high res data on AR2887 and the surrounding area in this seeing, but it didn't last, it quickly fell off the lower the sun got and soon it was gone, so my CaK suffered significantly compared to the rest. Still great to see such activity at that limb!
B&W:
Colored:
Seeing Conditions:
Equipment:
150mm F8 Refractor
+ Aries Full Aperture D-ERF + Baader Red CCD-IR Block D-ERF + 1.25x GPC (F10) + PST etalon & 10mm BF + IMX290 camera (HA high res)
+ Baader Cool Ceramic 2" Wedge + ND3.0 + Continuum 540nm + 2x Barlow (F16) + IMX290 sensor (WL high res)
100mm F10 Refractor
+ Lunt CaK B1200 module + 1.6x Barlow (F16) + IMX290 Sensor (Cak moderate res)
+ Lunt CaK B1200 module + IMX253 sensor (CaK disc)
+ Baader Cool Ceramic 2" Wedge + ND3.0 + Continuum 540nm + IMX253 sensor (WL disc)
Lunt LS60MT Refractor
+ HA etalon + 12mm BF + IMX253 sensor (HA disc)
AR2886, AR2887, AR2888 High Res | HA, CaK, WL | Oct 25th 2021
- Has thanked: 1188 times
- Been thanked: 1382 times
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: AR2886, AR2887, AR2888 High Res | HA, CaK, WL | Oct 25th 2021
Wow, well done Marty. Love the proms with everything else!
Dan
South central Indiana
USA
USA
Man, lots of post CME-loops on the eastern limb! I hope you guys on the other side of the globe get to see this! We're missing the best part of the show here!
https://sdo.gsfc.nasa.gov/assets/img/la ... 4_0171.jpg
- Has thanked: 17848 times
- Been thanked: 16985 times
Marty,
I knew when I saw that surge prom earlier on the NE limb that they were something there. I noticed an alert on SpaceWeatherLive on my phone at 02:46 UTC indicating an M1.3 class flare. I have yet to see post-flare loops.
https://helioviewer.org/?movieId=RsnN5
The flares are blasting off a lot of material, that's for sure!
Blessings,
Blessings,
These are incredible images and congratulations on the mention on Spaceweather too
- Has thanked: 9313 times
- Been thanked: 6151 times
An excellent series at all the lights, Marty. Nice to see you had a very productive session.
- rigel123
- Has thanked: 8573 times
- Been thanked: 8806 times
Great set Marty!
Marty, absolutely fab set of captures, presentation and added link too.
Exciting-times are upon us (or upon the Sun - even)...
Thanks for sharing
Thanks for sharing
- Has thanked: 6296 times
- Been thanked: 7320 times
Fantastic set of images, Marty!
Excellent work.
Arne
Excellent work.
Arne
