Oct 29 2021 - AR12887 & AR12889
- Has thanked: 1075 times
- Been thanked: 1986 times
I was in the middle of doing a high res mosaic and only got about 3/8s of the way and ran into AR12891 squeezing one out so I got distracted!!
- Been thanked: 8906 times
Re: Oct 29 2021 - AR12887 & AR12889
Wow!! very nice although after you said 'squeezing one out' all I could imagine during watching the ani was something else
- AJamesB
- Has thanked: 1154 times
- Been thanked: 630 times
Wonderful detail! If ya don't mind me asking, what is your setup (scope, camera, etc)?
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
- Been thanked: 4900 times
- Been thanked: 4427 times
Excellent work Simon
- arnedanielsen
- Has thanked: 6305 times
- Been thanked: 7324 times
Its a Daystar Gemini in Chrom mode, EvoStar 150 with UV/IR filter and a QHY174
- Has thanked: 17853 times
- Been thanked: 16995 times
Two thumbs up, Simon!!
- Has thanked: 8558 times
- Been thanked: 8290 times
Beautiful and excellent, Simon. Great work.
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Amazing images Simon!
You captured some very artistic moments of the active areas with all the 'movement' around them!
Thanks for sharing.
Alexandros
Thanks for sharing.
Alexandros
Alexandros
Greece
Greece
