November 2 2021 White Light Quickie!
Has thanked: 17807 times
Been thanked: 16948 times
Post by DeepSolar64 »
Session time is around 16:30 UTC. The skies are almost overcast. The temp is 52F ( 11.1C )
Orion 70mm Solar Telescope. 25x ( WL )
I can see three active regions on the solar photosphere today. AR12887 is visible nearing the SW limb as a single spot surrounded by faculae. Even using this low of a magnification the penumbra can be seen. AR12891 is visible just across the CLM as three spots with two having visible penumbrae. Due to it's location on the disc no faculae are seen. AR12893 is visible in the NE quadrant by a single spot bearing a penumbra and weakly visible faculae.
Carpe Lumen!
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: November 2 2021 White Light Quickie!
Post by EGRAY_OBSERVATORY »
Is that SolarMonitor image a little over-enthusiastic James?
Only three numbered AR's were visible around mid-day/Z that I could see and no other numbers were mentioned elsewhere other than those you have mentioned ?
Here the seeing was very clear at times, but slightly turbulent, so was about to try a Revolution R2 camera in the mini-obsy, but immediately a power-supply snag has meant I have had to repair the camera's power-socket and maybe tomorrow if clear, will try again for WL only at present.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Thanks for the report James!
Terry, the SolorMonitor site uses multiple band-pass filters and magnetometer data, which may not be visible as much but they do get NOAA numbers.
Not me Terry :lol: But SolarMonitor. But I can be enthusiastic! :D
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Thanks for the update James.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
EGRAY_OBSERVATORY
Thanks Brian..
Today I am under totally overcast skies. I don't see any chance of observing today.
EGRAY_OBSERVATORY
Thanks James.
WL only for visual showed much the same as yesterday at this morning/z
eroel
Been thanked: 4957 times
Post by eroel »
James, thanks for the report.
Regards.
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Good report James and thank you for continuing to do this despite the worsening conditions.
Ivan
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Thanks James.
Thanks and welcomes to all who took interest in my report here. :-)
Has thanked: 17924 times
Been thanked: 8889 times
Short and sweet, you got the main events :hamster: thanks James
Beautiful blue sky all morning here so decided to set up the PST for a lunchtime view, immediate cloud, where did that come from ?
Alexandra, scopes tend to attract them.
Has thanked: 20738 times
Been thanked: 10436 times
Thanks James. Quite a few clear skies for me at work this week, although I have been able to observe Jupiter and Saturn with the 100/800 which finally arrived. Very pleased with the scope, hoping to get it on the moon later in the month fingers crossed.
Mark,
That's great that your new scope is working well. I am glad you are enjoying some clear skies too!
