11-6-21: Cak and Continuum
- Has thanked: 1640 times
- Been thanked: 878 times
I had incredible seeing today.
Continuum: AR 2893
Image 1: 150 /F8 + 2x zwo 290
Image 2: 150/ F8 5x+ 290 (way over sampled) interesting comparison to 2xbarlow
2021-11-06-AR 2893 WL BW 2x290 by Diamond, Alan, on Flickr
2021-11-06-AR 2893 WL Color 2x290 by Diamond, Alan, on Flickr
2021-11-06-AR 2893 WL BWb 5x290 by Diamond, Alan, on Flickr
2021-11-06-AR 2893 WL Colorb 5x290 by Diamond, Alan, on Flickr
Continuum: AR 2894
2021-11-06-AR 2894 WL BW by Diamond, Alan, on Flickr
Cak
150 F8 masked to 60 + zwo 290
2021-11-06-AR 2893 CaK bw by Diamond, Alan, on Flickr
2021-11-06-AR 2893 CaK color by Diamond, Alan, on Flickr
2021-11-06-AR 2894 Cak bw by Diamond, Alan, on Flickr
2021-11-06-AR 2894 Cak color by Diamond, Alan, on Flickr
Continuum: AR 2893
Continuum: AR 2894
Cak
Re: 11-6-21: Cak and Continuum
Excellent captures Alan with the close-up of 2893 showing very well.
Thanks. I had exceptional seeing for my location. I wish it happened more often!EGRAY_OBSERVATORY wrote: ↑Sun Nov 07, 2021 11:45 am Excellent captures Alan with the close-up of 2893 showing very well.
- Been thanked: 4340 times
These are great pics Alan and seeing treated you well...nice work
ThanksMapleRidge wrote: ↑Sun Nov 07, 2021 12:30 pm These are great pics Alan and seeing treated you well...nice work
- Been thanked: 8792 times
Thanks
Im located in Fayetteville, Arkansas (USA). I live in a rural area and image over grass, trees and cows
- Has thanked: 17581 times
- Been thanked: 16696 times
The bright ring around the spot in AR12893 is visible in both of your CaK images.
You've met the November challenge!!
Awesome detail in white light too!
- Has thanked: 8418 times
- Been thanked: 8164 times
Excellent images, Alan, especially the WL images.
- Been thanked: 10248 times
These are all excellent Alan! What 150/8 scope are you using?
- VasilevIvan
- Has thanked: 397 times
- Been thanked: 264 times
Great images, Alan! Very interesting formations inside of the spot - light bridges cross the umbra of this spot.
BW, Ivan
BW, Ivan
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
The Celestron C6R 150/1200 achromat. It is not as well corrected as my 102f11 achromat in the UV.marktownley wrote: ↑Mon Nov 08, 2021 7:44 pm These are all excellent Alan! What 150/8 scope are you using?
Thanks. I have been trying to adjust my capture and processing to better show umbral details but keeping good granulation. I really liked the umbral dots and light bridge in this image.VasilevIvan wrote: ↑Mon Nov 08, 2021 7:49 pm Great images, Alan! Very interesting formations inside of the spot - light bridges cross the umbra of this spot.
BW, Ivan
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
- Has thanked: 6181 times
- Been thanked: 7142 times
Stunning work, Alan. Very sharp and beautifully processed!
Arne
Arne
