Nov 7th Prominence
RKBerta
Has thanked: 54 times
Been thanked: 73 times
Nov 7th Prominence
Post by RKBerta »
Had decent weather today so got a bunch of images. Only processed one thus far due to limited time. Was a nice detailed prominence with lots of sharp resolution details. I combined the Prominence with the Chromosphere image in PS. Excuse the topic title....it isn't the Corona ;-) Tried to correct topic title but couldn't do it without deleting the post.
This was with Coronado 60mm Etalon single stacked with the BF30 both older US built camera is a Player One Neptune mono camera. It has the Sony 178 chip and on board 256 DDR. Mount is an Ioptron ALT/AZ cube pro. Telescope is a 80mm APO Officina Stellare.
13_13_59_Big Prominence Nov 7 2021_l6_ap2_conv-2.jpg (1.46 MiB) Viewed 337 times
80mm f6 Officina Stellare APO triplet, 152mm Officina Stellare f8 APO triplet, TV 85mm f7 ED APO, 8" SCT HD, 11" SCT.
Astro Physics 900 and 1100 mounts, Ioptron MINI Tower Pro ALT/AZ mount, ZWO AM5 mount,
Lunt 60mm Ha single stack, Coronado 60mm Ha single stack with BF 30
Day Star Quark Chromosphere
Player One Neptune mono with 178 chip, 256mm DDR, tilt plane for solar imaging
ASI 071 Pro cooled color for DS imaging
ATIK 490 EX OSC for DS imaging
SBIG STL 6303e mono with RGBL and Ha, SII, OIII filters for DS imaging
ASI AIR Plus
JPL/NASA Solar System Ambassador
Michigan Scout observatory manager
Has thanked: 17813 times
Been thanked: 16952 times
Re: Nov 7th Corona and Prominence
Post by DeepSolar64 »
The moderators may be able to help you correct the post. That prom is very bright in your image. Certainly brighter than I saw it visually today. What time did you take the image? It looks a fair amount different that it did when I observed it.
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Very nice prom shot. Lots of fine detail.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Well done.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Excellent prom shot Robert.
Thanks for sharing
Has thanked: 17925 times
Been thanked: 8894 times
Re: Nov 7th Prominence
That's a very large prom and lots of intricate detail, very nice indeed :bow :hamster:
Has thanked: 20749 times
Been thanked: 10439 times
Good shot!
eroel
Been thanked: 4957 times
Post by eroel »
Robert:
Very nice image.
RKBerta
Re: Nov 7th Chromosphere and Prominence
Post by RKBerta »
DeepSolar64 wrote: Mon Nov 08, 2021 3:06 am The moderators may be able to help you correct the post. That prom is very bright in your image. Certainly brighter than I saw it visually today. What time did you take the image? It looks a fair amount different that it did when I observed it.
James....that was taken on Nov 7th at 12:30pm in Michigan USA. There were two images....one for prominence and another for Chromosphere....combined both but could have lightened Chromosphere part so better balance. I am new at this so still getting it figured out. I was mostly trying to get the faint bits of the prominence that are above the brighter part and pulling away. The prominence was pretty bright through the 60mm Ha Coronado single stack etalon equipped 80mm Officina Stellare APO refractor. The visual image was bright and those fine lines of the prominence coming from the sun were quite fine and well defined.
Thanks for your comments...by the way the moderators did fix the title mistake for me :D
ASI AIR Plus
