M-Class flare and following Post-Flare loops! Beautiful!!
- Been thanked: 16694 times
Session time from 17:00 until 19:00 UTC. Skies are clear with just below average seeing. The temperature is 75F ( 23.8C ) at 18:30 UTC.
Coronado SolarMax II 60 SS. 16x, 21.5x, 25x, 33x and 50x ( Ha )
At 17:00 UT I got an alert on my SpaceweatherLive app warning of an ongoing M-class solar flare. I had only taken down my SolarMax 90 about 20 minutes earlier. I cursed a bit then quickly grabbed the smaller SMII60 and whisked it outside hoping to catch the flare as the SDO data showed it on the NW limb. Looking through the scope I saw no trace of the flare itself! Even GONG Ha images hardly show it at all. However SDO easily picked it up. However I could see a bright but small set of prominences being quickly ejected from the site. These within a few minutes started showing structure and developed into a beautiful and easy to see set of post-flare loops. I was delighted! They are absolutely beautiful to behold with their graceful curving shapes. The tops of the loops are brighter than the lower extremities but they are still not difficult to see. They actually look better in the scope than what the GONG images show. If they would have happened an half hour earlier I would have gotten an even better view in the SMII90. But I still was not disappointed. In the SDO images the loops are simply stunning. I hope someone here caught them today.
Here's the image data.
Goodnight.
Goodnight.
- Been thanked: 10246 times
Re: M-Class flare and following Post-Flare loops! Beautiful!!
Thanks for the update James, I hope the sun is this busy when I finally get some decent weather.
marktownley wrote: ↑Wed Nov 10, 2021 6:30 am Thanks for the update James, I hope the sun is this busy when I finally get some decent weather.
You are welcome. Those loops were really pretty.
Thanks James and this flare actually affected Earth communications, so was certainly very powerful, even though was the other-side of the limb.
- Been thanked: 4787 times
- Has thanked: 8418 times
- Been thanked: 8163 times
Darn these grey skies…..
Thanks for showing us what we’re missing, James.
- Has thanked: 1640 times
- Been thanked: 878 times
Nice report and thanks for sharing. I watched the videos on SDO and gong. I hope to see one in the future
- Has thanked: 9145 times
- Been thanked: 6025 times
Thank you, James, for the report. Those loops are magnificent.
- Been thanked: 8791 times
I am so happy for you James, I've only ever seen them about twice before through the PSTs, I would love to see them through the 100mm Solarscope or even in the SolarSpectrum. May be one day
Thanks everyone for your replies and comments. I am glad I got the event. It looks like I may have been the only one at the time to see it. Now I am waiting for an X Class flare!!
https://helioviewer.org/?movieId=xtWN5
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Congratulations James! I also saw the alert in the app, but at this time we had a clear dark evening
Ivan
Ivan
Yep. Dark means virtual viewing only.
- Been thanked: 4340 times
Congrats on being able to catch the post flare loops...rare sight but you were prepared and went out when you got the notice.
MapleRidge wrote: ↑Thu Nov 11, 2021 5:58 pm Congrats on being able to catch the post flare loops...rare sight but you were prepared and went out when you got the notice.
Yep, I was available to do so at the time. It payed off.
Hi James,
Beautiful images and well done for catching them. Excuse my ignorance, but what is SDO?
John
John
John,
The SDO is NASA’s Solar Dynamics Observatory in Earth orbit. It images the Sun almost continuously in wavelengths from continuum all the way down into the extreme ultraviolet. It’s NASA’s premier solar observatory.
James.
James.
