Sun FD in H-Alpha 12th of November 2021
- Has thanked: 6305 times
- Been thanked: 7327 times
Dear friends,
Only managed to image in H-Alpha during the short period from the Sun cleared some local obstacles to the clouds moved in. No time for flats either so had to reuse the flats from last session.
Solar altitude 6,5 degrees.
FD image in H-Alpha using a Coronado 60mm/BF15 w/Beloptik ITF, stopped down to 50mm, Baader 35nm H-Alpha and ASI 178mm mounted on a SkyWatcher SolarQuest. Sun FD in H-Alpha 12th of November 2021
Sun FD in H-Alpha 12th of November 2021 - Colorized
Click on links to view full size images.
Thanks for looking and best regards,
Arne
Arne
- Ivan
- Has thanked: 3489 times
- Been thanked: 2267 times
Re: Sun FD in H-Alpha 12th of November 2021
Incredible 6.5 degrees and such a great disk! Arne, what was the temperature at the time of filming?
Ivan
Ivan
- Been thanked: 4981 times
Arne:
Super shots, specially when taken at that solar altitude.
Best wishes.
Best wishes.
- Been thanked: 4881 times
- Been thanked: 8907 times
That' s a beauty!! that's a very low angle, it is a pain at this time of the year when trying to drive, the Sun is always in your eyes (if it is out that is).
- Has thanked: 8559 times
- Been thanked: 8297 times
I always admire your crisp, clean, uniform Ha FDs, Arne. Nicely done.
Thank you so much Ivan, Eric, Maurits, Alexandra and Stu for your kind comments!
Ivan: The temperature was a pleasant 2 degrees C.
Eric: I was hoping to image the Sun closer to noon for a slightly higher solar altitude, but in came the clouds :-(
Alexandra: Yes, a low Sun can be challenging when driving. A clean front window is an absolute must!
Stu: Your images, along with others on this forum, has been of great inspiration!
Arne
Arne
- rigel123
- Has thanked: 8589 times
- Been thanked: 8822 times
Excellent disk Arne, particularly at that altitude!
- Has thanked: 9327 times
- Been thanked: 6163 times
Beautifully done in challenging conditions, Arne.
- Ivan
Arne, congratulations on SPoD!arnedanielsen wrote: ↑Sun Nov 14, 2021 11:12 am Thank you so much Ivan, Eric, Maurits, Alexandra and Stu for your kind comments!
Arne
And thanks for the answer, we now have the same temperature, but I'm afraid to take my Lunt out into the street, I'm afraid that the cold and moisture can harm it. After the session, it somehow needs to be specially stored, do you need any actions? I mean silica gel or something else?
Ivan
- Been thanked: 4434 times
Beautiful full disk images Arne...well done
- Has thanked: 20828 times
- Been thanked: 10502 times
Great looking disks Arne!
Thank you so much everyone for your kind comments!
Arne
Arne
Thank you Ivan,Ivan wrote: ↑Sun Nov 14, 2021 12:36 pmArne, congratulations on SPoD!arnedanielsen wrote: ↑Sun Nov 14, 2021 11:12 am Thank you so much Ivan, Eric, Maurits, Alexandra and Stu for your kind comments!
Arne
Ivan
The SPoD was a nice suprise!
When it above freezing I usually just put the scope in the living-room, but when it's sub-zero I usually wrap the scope in some isolating material (preferably in an airtight wrapping) before bringing it inside and let it warm up very slowly. After it has reached indoor temperature I unwrap it to let it breath.
Due to the low Sun I don't get to use the solarscopes that much during wintertime.
Arne
- Ivan
