Sunday Sun November 14th 2021
- Has thanked: 8559 times
- Been thanked: 8291 times
Another spell of sunshine here and an opportunity to capture some rays in Ha of the two main active regions and a filaprom.
All taken with my 150 mm DS Lunt 35 mod.
Basler acA1920-155um camera
2.5x PM
Genika Astro
AS!3
ImPPG
PixInsight
First up is AR12895
20211114_Ha_AR12895 by Stuart Green, on Flickr
AR12894 approaching the western limb, including a 3 pane mosaic across the active region.
20211114_Ha_AR12894 by Stuart Green, on Flickr
20211114_Ha_AR12894_Mosaic by Stuart Green, on Flickr
.....and the filaprom.
20211114_Ha_Prom by Stuart Green, on Flickr
Thanks for looking.
2.5x PM
Genika Astro
AS!3
ImPPG
PixInsight
First up is AR12895
Thanks for looking.
- Has thanked: 54 times
- Been thanked: 73 times
Re: Sunday Sun November 14th 2021
Nice images . Here in Michigan, USA we have light rain and some snow flakes.... Should be much better next week.
80mm f6 Officina Stellare APO triplet, 152mm Officina Stellare f8 APO triplet, TV 85mm f7 ED APO, 8" SCT HD, 11" SCT.
Astro Physics 900 and 1100 mounts, Ioptron MINI Tower Pro ALT/AZ mount, ZWO AM5 mount,
Lunt 60mm Ha single stack, Coronado 60mm Ha single stack with BF 30
Day Star Quark Chromosphere
Player One Neptune mono with 178 chip, 256mm DDR, tilt plane for solar imaging
ASI 071 Pro cooled color for DS imaging
ATIK 490 EX OSC for DS imaging
SBIG STL 6303e mono with RGBL and Ha, SII, OIII filters for DS imaging
ASI AIR Plus
JPL/NASA Solar System Ambassador
Michigan Scout observatory manager
ASI AIR Plus
- Ivan
- Has thanked: 3485 times
- Been thanked: 2263 times
Stu, this is great!
I understand correctly that you are using DS, if this is, how it is implemented?
Ivan
Ivan
You lucky piglet Stuart!! I saw that crack of sunshine hovering over you all day today. We were just on the edge and it never got here until 3pm when the Sun had gone out of my viewing window. Not envious in the slightest, honest
Tremendous images by the way
Hi Ivan,
Yes, it’s double stacked. I have two Lunt 35 etalons working in tandem on the rear of my scope behind a Barlow that makes the light cone substantially parallel and feeds this into the etalons. There’s a refocusing lens behind the etalons to bring the Sun back into focus on the sensor.
Ha…ha…it makes a change for Preston to get the Sun. As I say, you’re always welcome here.Montana wrote: ↑Sun Nov 14, 2021 6:22 pm You lucky piglet Stuart!! I saw that crack of sunshine hovering over you all day today. We were just on the edge and it never got here until 3pm when the Sun had gone out of my viewing window. Not envious in the slightest, honest
I struggled to get these images any sharper today for some reason.
Many thanks, everyone. Much appreciated.
- Been thanked: 4427 times
Superb images Stuart
You have done well again Stu to produce these excellent images.
Keep a watch at the S.E.Limb for the newbie as AR289(6)..
Beautiful images Stu, just stunning. No sun down here in SE England for days, but your images have brighten my day.
John
John
- Has thanked: 17853 times
- Been thanked: 16998 times
Stuart,
Your images mirror Pedro's very closely. Very similar in detail and quality. The features have changed little also.
- Been thanked: 10489 times
You had 2 days of sunshine Stu! Very nice images!
- Ivan
Stu, thanks a lot for the detailed answer.Carbon60 wrote: ↑Sun Nov 14, 2021 8:09 pmHi Ivan,
Ivan
- Has thanked: 9324 times
- Been thanked: 6157 times
Much appreciated, guys.
- Has thanked: 6305 times
- Been thanked: 7324 times
This set of images is really great, Stu.
Excellent contrast and detail.
