Solar on Nov. 18th. ES127APO+QUARK+ Apollo-M MAX (IMX432) cam
- MoonPrince
- Has thanked: 7 times
- Been thanked: 228 times
Hi Guys, today's Sun image all done. Very lucky day to see a new thing AKA "filament" on Solar surface. It's my first time to capture such thing, it looks very cute. In another image, there is an active area, one big prominence.
Some one asked my filter, it's a Quark with UV IR-cut filter. My friend suggest to put an 30nm Ha filter before Quark as a ERF.
Normal pattern:
Reverse pattern:'
Prominence today:
Gear info:
Telescope: ES127 CF APO
Mount: SW AZEQ6
Camera: Player One Astronomy Apollo-M MAX (IMX432)
Filter: Daystar Quark Chromosphere.
Capture: Exp=8ms, Gain=160, 2000 frames, 30% stacked.
Software: AS!3, AstraImage5, Photoshop CC.
Normal pattern:
Reverse pattern:'
Prominence today:
Gear info:
Mount: SW AZEQ6
Telescope: ES127CF APO F7.5, LXY80APO F6
Mount: SW AZEQ6, iOption GEM45.
Camera: Player One Apollo-M MAX(IMX432), Apollo-M(IMX174), Apollo-M MINI(IMX429)
Accessories: Daystar Quark Chromosphere, Herschel prism, TV5X, TV2.5X
- Has thanked: 8543 times
- Been thanked: 8278 times
Re: Solar on Nov. 18th. ES127APO+QUARK+ Apollo-M MAX (IMX432) cam
A great set of images. Nicely done.
- Been thanked: 4421 times
Excellent images
A very productive scope/filter/camera setup with great image processing too!
- Been thanked: 4971 times
Hi:
Beautiful images all of them.
Thanks for sharing them.
- Has thanked: 17970 times
- Been thanked: 8904 times
Wow!! these are really lovely I really like the big filament (nearly soon to be a filaprom)
- pedro
- Has thanked: 14 times
- Been thanked: 6689 times
Great images, your Quark seems to be in good working order
Pedro Re'
- Has thanked: 1313 times
- Been thanked: 64 times
Congratulations on such super images.
John
John
Indeed absolutely super images and thanks for sharing
- Has thanked: 9307 times
- Been thanked: 6144 times
Beautiful pictures and coloring MoonPrince
- Has thanked: 20779 times
- Been thanked: 10462 times
A nice set of images!
- MoonPrince
Thank you, Stu. After two days shoot, I thought seeing on this day was the best in last week!
- MoonPrince
Hi Brian, I replace UV IR-cut filter in next day with a R filter. I think it will be better to block heat. ES127+QUARK+Apollo-M MAX is impressived me a lot.MapleRidge wrote: ↑Fri Nov 19, 2021 2:22 am Excellent images
- MoonPrince
Thank you, Eric. I just post some images of 19th.
- MoonPrince
Hi Alexandra, I checked the filament in next day and it was grow up.
- MoonPrince
Thanks, Maurits. I watched some solar processing videos on Youtube, they teach me a lot.
- MoonPrince
Yes, this Quark is quite new, I just bought it one week ago.
- MoonPrince
Thanks a lot, John. Still learning about solar processing.
- MoonPrince
Thank you, Terry. I'm working on new image sets after 18th.EGRAY_OBSERVATORY wrote: ↑Sat Nov 20, 2021 12:19 am Indeed absolutely super images and thanks for sharing
- MoonPrince
Thanks a lot, man. I will try solar mosaic in next clear day. I did a lot of lunar mosaic before, but not sure if solar is as easy as lunar
- Ivan
- Has thanked: 3479 times
- Been thanked: 2260 times
Nice set, thanks for sharing.
Ivan
Ivan
