Session time is from 16:10 until 16:30 UTC. The skies are overcast with high thin clouds. Fair seeing. The temperature is 54F ( 12.2C )
AR12896 is visible as a single small spot now in the SW quadrant with a small pore to it's SE. I see no penumbra associated with the spot. AR12897 just west of the CLM is visible also by a single small spot. I see no sign of a penumbra with it either.
I see a patch of faculae well inside the SE limb and another facula well inside the SW limb. No spots or pores are seen in any of these.
The granulation is weakly visible.
Carpe Diem!
November 21 2021 Observations. WL Only, Again.
- Been thanked: 16694 times
- Been thanked: 8791 times
Re: November 21 2021 Observations. WL Only, Again.
Thanks for the WL report James I was able to observe only in Halpha and CaK today as I had super sunshine you have completed my set
Post yours and you have completed my set. I have gotten only white light today. I am glad you had sunshine. I am viewing through clouds.
Thanks vm James.
I had no chance this afternoon due to those pesky clouds here...
EGRAY_OBSERVATORY wrote: ↑Sun Nov 21, 2021 10:28 pm Thanks vm James.
You are welcome, Terry. I barely got the chance myself and a short time later the clouds had gotten too thick to see the Sun at all.
- Been thanked: 4340 times
Nice to see your report on WL features James!
I did get time to do Ha work this morning, images to come.
Brian,MapleRidge wrote: ↑Mon Nov 22, 2021 1:42 am Nice to see your report on WL features James!
I am sure you did better on your Ha images than I did with white light today. There is not a lot to see on the photosphere.
- Been thanked: 4904 times
James:
Thanks for the report, I had the chance to get some shots.
Best regards.
Best regards.
You are welcome, Eric. I will check them out when you post them. Your work is always good.
JP
JP
- Been thanked: 10247 times
Thanks James!
