Sol from the 25th of November 2021.
eroel
Been thanked: 4957 times
Post by eroel »
Hi:
Got some images, seeing jumpy and sky hazy and cloudy, so just had a quick chance to image.
Thanks for looking.
Wish you all a nice and sunny weekend.
Sol del 25 de noviembre 2012-Solarmax 90-DS-BF30-1pos.jpg (959.89 KiB) Viewed 477 times
Sol del 25 de noviembre 2012-Solarmax 90-DS-BF30-1neg.jpg (986.54 KiB) Viewed 477 times
Sol del 25 de noviembre 2012-Stellarvue-Daystar-1az-s-pos.jpg (1.48 MiB) Viewed 477 times
Sol del 25 de noviembre 2012-Stellarvue-Daystar-3az-pos.jpg (1.39 MiB) Viewed 477 times
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: Sol from the 25th of November 2021.
Post by EGRAY_OBSERVATORY »
Considering either you or the seeing was jumping around Eric, you have still captured an excellent set of images.. :lol: :seesaw
Thanks for sharing and have a good weekend - not jumping around either !! :P
Regards
terry
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Well done, Eric!
Ivan
eroel
Post by eroel »
Terry and Ivan:
Thanks for the feedback, as for the seeing, well here is the SSM graph of the 25th, normally when sunny and mostly clear, the input shows 0.8, so as you can see it was lower and the seeing with interruptions due to clouds passing by and jumpy.
Have a nice weekend too.
Has thanked: 8523 times
Been thanked: 8251 times
Post by Carbon60 »
A great set of images, Eric.
Has thanked: 17807 times
Been thanked: 16941 times
Post by DeepSolar64 »
Very nice detail Eric. I notice especially the last one of the southern prominence. :-)
EGRAY_OBSERVATORY
Thanks for that description and the image Eric.
Here in much of the U.K. and particularly my region in the S.E., any scopes outside or not tied down will likely be jumping around, due to the high/very-high winds forecasted. Then even covered in snow is a possibility..
eroel
Post by eroel »
Stu, James and Terry:
Thanks for commenting.
As for jumping seeing, I mean that the seeing is changing continuosly with no steady repeating periods.
My home observatory is on the roof and I have the 4 scopes mounted on a sturdy permanent steel pier, but cars and trucks passing in front of my house, make my setup vibrate a bit, so I have to take that in account also when imaging.
Best wishes for you all.
Eric, with the observatory not on the ground floor on a concrete pad you must have one sturdy house to mount that steel pier in!!
jacinto
Has thanked: 595 times
Been thanked: 140 times
Post by jacinto »
Great Picures Eric !!!
Jacinto
Has thanked: 64 times
Been thanked: 4406 times
Post by MapleRidge »
Superb images Eric...well done :bow
Has thanked: 20738 times
Been thanked: 10428 times
Great images Eric!
Has thanked: 17888 times
Been thanked: 8887 times
Beautiful images, especially the last one of the prominence :bow :hamster:
arnedanielsen
Has thanked: 6276 times
Been thanked: 7288 times
Post by arnedanielsen »
Very nice despite the not so favorable conditions.
Thanks for sharing,
Arne
Arne
