1st Dec Full Disk
- minhlead
- Has thanked: 739 times
- Been thanked: 1107 times
1st Dec Full Disk
I think I improved a bit on sharpness by increasing the gain and lower exposure time. Was 1.8ms and have quite a lot of blurriness across the disk. Now I am exposing for about 0.4 ms and the result look much sharper.
Minh.
Loves from Viet Nam <3
My gear:
Scope: SkyRover (Kunming Optics) 152mm F/6 Doublets
Mount: JTW Tridents GTR
Camera:
PlayerOne Apollo M-Max
Quark Chromosphere Doublestacked with PST etalon
My gear:
Camera:
- Been thanked: 8906 times
Re: 1st Dec Full Disk
Oh yes!! very very nice indeed it looks a bit more on band today also
- rigel123
- Has thanked: 8576 times
- Been thanked: 8810 times
That shorter exposure is much better.
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- minhlead
Yeah. The last few days I did not turn on the cooler. Thought I do not need it since it's winter and ambient temperature is around 20*C. But apparently my Quark still requires the cooler to be onband.
Minh.
My gear:
Camera:
My gear:
Camera:
- minhlead
Yeap. Did not expect such a big improvement. I have never ever thought 2ms exposure is still too long. I used to shoot planetary and anything under 5ms is more than enough to beat the seeing. Apparently solar need much shorter exposure time.
Minh.
My gear:
Camera:
My gear:
Camera:
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
Interesting. My own exposures are around 10ms at this time of year. [Weather permitting.]
Opinions seem to vary widely on whether this is short enough to beat the seeing.
I used to try and get exposures as short as possible even at the cost of increased gain.
The Lunt B1200S2 is very dim compared with the PST BF5. I now only use the latter on proms.
Congratulations on your SPOD.
- minhlead
I am surprised too. But some gain is not a bad thing. A right amount of gain would induce some random noise which in turn will increase bitdepth of the stacked image.Rusted wrote: ↑Wed Dec 01, 2021 4:07 pmInteresting. My own exposures are around 10ms at this time of year. [Weather permitting.]
https://www.stark-labs.com/craig/resour ... acking.pdf
If you have the time, read this. A very compelling read on the impact of stacking on bitdepth.
Minh.
My gear:
Camera:
My gear:
Camera:
- Been thanked: 4900 times
- rigel123
I misread his original exposures, because I am typically between 2 - 10 ms so you are right, the change shouldn't have made that big of an improvement so I wonder if it was a change in seeing instead.Rusted wrote: ↑Wed Dec 01, 2021 4:07 pmInteresting. My own exposures are around 10ms at this time of year. [Weather permitting.]
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- Has thanked: 17853 times
- Been thanked: 16996 times
Very nice!! It just needs to be rotated.
JP
JP
- minhlead
Ha ha. I agree.
I switched several time between exposure time and the result is the same. Shorter exposure always sharper.
Thanks Terry. I am honored.
Minh.
My gear:
Camera:
My gear:
Camera:
- Has thanked: 1640 times
- Been thanked: 878 times
And congratulations on the SPOD!!
- Rusted
Thanks for the link.minhlead wrote: ↑Wed Dec 01, 2021 4:22 pm
I am surprised too. But some gain is not a bad thing. A right amount of gain would induce some random noise which in turn will increase bit depth of the stacked image.
If you have the time, read this. A very compelling read on the impact of stacking on bit depth.
There is a balance [seesaw effect] with relation to FPS and Gain.
As exposure shortens the Frames Per Second simultaneously go up.
This provides more frames to stack in a given time period.
Meaning more data + less drift during the total capture period.
I find that things go bad when SharpCap Gain approaches 200 in winter.
This may not be true for wider fields.
I am only ever imaging at high resolution with tiny fields of view.
150/10 =1500mm x [1.6 or 2x or 2.6x] GPC x [IMX174] Sensor Crop Factor.
