AR12887 on Oct-28 2021 ARIES DERF+SW150mm F/5 + QUARK
Hi all,
This cloudy evening I have some time to process a well belated image of the AR12887 which I have captured Oct.29 2021 with SkyWatcher 150mm F/5 refractor equipped with a full aperture ARIES DERF, 2x NPZ Barlow lens, QUARK Chromosphere, GSO 0.5x reducer and Basler 1920-155 camera.
The seeing was mostly poor, but I was lucky to catch some seeing improvements. This photo was taken during such a moment.
FireCapture 2.6, AS!3, AstraImage 3.0 were used for image recording and processing.
Thanks for looking.
Valery.
Thanks for looking.
Valery.
- 2021-10-29 UT9h32m ARIES DERF 150mm QUARK-Chr.jpg (406.77 KiB) Viewed 596 times
Re: AR12887 on Oct-28 2021 ARIES DERF+SW150mm F/5 + QUARK
Very fine image with extreme detail Valery.
Thanks for sharing
Thanks for sharing
- Been thanked: 4340 times
Excellent capture Valery...nicely done
- Been thanked: 4904 times
Valery, superb image.
Thanks for sharing it.
- Has thanked: 20424 times
- Been thanked: 10242 times
Excellent results Valery! How do you find the NPZ barlow performs?
This 2x barlow performs well in this setup. Didn't compare with other Barlows.marktownley wrote: ↑Sun Dec 05, 2021 8:28 am Excellent results Valery! How do you find the NPZ barlow performs?
Valery.
- Been thanked: 2712 times
Hello Valery,
Very nice active region. Thanks for sharing !
- Has thanked: 8415 times
- Been thanked: 8161 times
Great image, Valery, in your trademark style.
- pedro
- Has thanked: 14 times
- Been thanked: 6573 times
Great image Valery
Did you use flats with the Quark. I noticed that my Quark Chromosphere is getting worse every day. I have to use flats all the time
Pedro Re'
Yes, Pedro, I have used a Flat (build in the Fire Capture option). However I did this to correct the vignetting and to get rid of the dust particles shadows.
- rigel123
- Has thanked: 8309 times
- Been thanked: 8536 times
Lovely swirls around that AR, great image!
- Has thanked: 54 times
- Been thanked: 73 times
Great image Valery.
80mm f6 Officina Stellare APO triplet, 152mm Officina Stellare f8 APO triplet, TV 85mm f7 ED APO, 8" SCT HD, 11" SCT.
Astro Physics 900 and 1100 mounts, Ioptron MINI Tower Pro ALT/AZ mount, ZWO AM5 mount,
Lunt 60mm Ha single stack, Coronado 60mm Ha single stack with BF 30
Day Star Quark Chromosphere
Player One Neptune mono with 178 chip, 256mm DDR, tilt plane for solar imaging
ASI 071 Pro cooled color for DS imaging
ATIK 490 EX OSC for DS imaging
SBIG STL 6303e mono with RGBL and Ha, SII, OIII filters for DS imaging
ASI AIR Plus
JPL/NASA Solar System Ambassador
Michigan Scout observatory manager
ASI AIR Plus
- Has thanked: 17648 times
- Been thanked: 8787 times
You never fail to make a smile Valery, superb
- pedro
Thanks Valery
I am using flats to correct my Ha images most of the times (High resolution imaging)
Pedro Re'
- Has thanked: 6181 times
- Been thanked: 7142 times
Beautiful capture and processing, Valery!
Arne
Arne
