Testing some filters with the MiniSHG....
On CWL (K3) (3933.7A) the plage and chromospheric network shows well and also the very large filament down south.
Moving towards the violet (K2v) and the filament is still visible.
When moved to the red side (K2r) the filaments fade and the brightness of the active areas is enhanced .
CaK and very large filament 5th Dec 21
- Has thanked: 173 times
- Been thanked: 615 times
- Been thanked: 16691 times
Re: CaK and very large filament 5th Dec 21
A couple of prominences are visible on the first and last image too!
- Been thanked: 4340 times
Great t see your CaK capture Ken, and the prom looks good
- Been thanked: 4904 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Stunning images Ken, that SHG is the business. The images you have been posting CaK are a reference. They've certainly been giving me some ideas for tweaking my CaK filter for next year. I know I can't get the tight bandpass of the SHG, but I think there may be gains to be had on my filter system yet.
- Has thanked: 17667 times
- Been thanked: 8787 times
Wow!! look at that filament!! I've not seen the Sun for a while so I am a bit behind, looks like this weekend the Sun was a stunner
- pedro
- Has thanked: 14 times
- Been thanked: 6576 times
Fantastic images Ken, thanks for sharing
Pedro Re'
- Has thanked: 8415 times
- Been thanked: 8161 times
Great images there, Ken.
