December 19 2021 Observations. The Sun is Alive, and Smiling!!
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
Session time is from 18:30 until 19:16 UTC. The skies are partly cloudy with poor seeing. The temperature is 49F ( 9.4C )
The Sun is loaded today with plages and active regions! They are six numbered active regions in the southern hemisphere and two numbered active regions in the northern hemisphere. In addition to these several other unnumbered systems are visible. AR12906 and AR12907 are in the SW quadrant. Despite the poor seeing I can still make out filaments in both of these systems. AR12908 and AR12909 are just over the CLM in the SE quadrant. Two fine filaments can be seen within AR12908. I can see spots in AR12907-908 and 909 as well. An easy group of plages is seen in the far SE quadrant. Only one of these are numbered ( AR12912 ) but I can pick out seven plages here alone! One of these is divided by a filament so it may actually be one system. AR12912 is at the NE corner of the plage grouping and has a single tiny spot that is more easily seen in white light. Just to the east of AR12912 is another plage of the group. The NW quadrant shows the plage of AR12910. The GONG Cerro Tololo image shows a spot there but it's a bit small to see at the low magnifications I am using. AR12911 is seen in the NE quadrant as a plage with a spot on it's western side. The brighter part of the plage is east of the spot. I can also see a disturbance in the far NE.
An easy long patchy filament lies south of the AR12907-908 complex. Another lies SE of AR12909. I can see six filaments in the NW quadrant as well.
Prominences are few and small today. I notice only three. Two on the NE limb and one on the SW limb.
The mottles are seen without difficulty today.
To summarize Ha today I think I did surprisingly well despite the poor seeing. Using this small Ha refractor at such a low magnification helps negate seeing. As well as using the current GONG Cerro Tololo image as a guide I also used Stuart Green's earlier FD Ha image since it gave a more contrasty and sharper view than GONG does. Even though he took it a bit earlier the Sun hadn't changed that much so it proved of value. Thanks Stuart!!
Orion 70mm Solar Telescope 25x and 41.5x ( WL )
Today I stayed below 50x because of poor seeing. I can see fourteen systems on the continuum photosphere today! Six numbered in the south and two numbered in the north. The remaining ones are unnumbered systems. AR12906 in the SW is visible as a single spot. No other detail is seen in it. AR12907 is a smattering of pores and small spots with a larger one at the eastern end of the group. Despite the low magnification and poor seeing I can still make out a penumbra around a dark umbra to it. AR12908 is a fair sized spot with a smaller one to it's SE. AR12909 shows a fair sized spot with a penumbra. I can see a pinching in of the umbra barely. SDO shows a light bridge there that I cannot resolve. I can see a few more small spots/pores in it's vicinity including one to the east of the bigger spot. With these lined up spot groups it's hard to tell where one ends and the other begins!!
I can see six patches of faculae in the far SE quadrant. Three of these contain spots. The two westenmost ones are single pores. SDO shows two in the NW one is actually not single but two. I cannot see the tiny second one. The NE faculae belongs to AR12912. I can see a single not too-small-spot. SDO shows a penumbra but I cannot make it out.
AR12910 in the NW shows a spot and pore amid faint faculae. AR12911 in the NE shows a single sizeable spot. I can only barely make out it's penumbra. No faculae visible here. I can see a fairly bright patch of faculae near the NE limb. SDO HMI continuum imagery shows a single pore here but I cannot see it.
I cannot make out the granulation at all today.
Today's music is Winter Songs by Ola Gjeilo.
Carpe Noctem!
P.S. Is ol' Sol smiling in a wicked sort of way or is it a frown? Look at those wide set eyes! In Stu's image he looks like the " Great Pumpkin "!!
Has thanked: 20756 times
Been thanked: 10442 times
Re: December 19 2021 Observations. The Sun is Alive, and Smiling!!
You got a nice report in there James, looks like another day of grey skies for me. Think it's going to be a day of hifi and music...
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Great report James, thanks! So many activities and details. I also noticed that the Sun looks like a smiley or a mustachioed gentleman :) but the pumpkin is perhaps the most apt comparison.
Ivan
Has thanked: 8523 times
Been thanked: 8258 times
Post by Carbon60 »
Thanks for your detailed report, James, and reference to my images. Much appreciated.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Thanks again for your excellent report James..
In fact as of 11:00z today/20th, there are in fact now nine AR's, so my next post will explain more...
Has thanked: 17925 times
Been thanked: 8894 times
Thanks for the excellent report James, looks like I will be clouded out forever ;)
Thanks everyone for your comments and input. ☑️
And thank you Stu for use of that wonderful image! And Mark, hifi music 🎶 sounds good to me. Have a beer 🍺 with that! And Alexandra, I hope the Sun ☀️ finds you soon.
