A little flare action at AR2907
- rigel123
- Has thanked: 8328 times
- Been thanked: 8554 times
I started this animation run at 15:26 UT and at about 16:00 UT you can see the start of a flare north of the spot and then it really explodes quickly south of the spot followed by an eruptive filament that does not last long. You can also see the effects of the BF cooling down as contrast nearly disappears near the end of the 45 minute animation. That was even with the Lunt BF heater running. It was about 30 F at the time.
Flare-around-AR2907-12-20-2021 by Rigel123, on Flickr
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- Has thanked: 8420 times
- Been thanked: 8173 times
Re: A little flare action at AR2907
Solar dynamics in action. Nice one, Warren.
- Has thanked: 17583 times
- Been thanked: 16708 times
WoW, I just missed it. It happened Less than an hour before I set up. That's a much better view than I would have gotten visually and there's nothing better than a good animation like yours to bring the Sun to life!
Thanks Warren.
Thanks Warren.
- Has thanked: 17672 times
- Been thanked: 8795 times
- Has thanked: 9149 times
- Been thanked: 6030 times
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Thanks for the great animation, Warren. We are now at -23C and I am not capturing, although the weather is clear.
Ivan
Ivan
- Been thanked: 4904 times
Warren, a very nice animation.
Thanks for sharing it.
Best wishes for this comming X´mas.
- rigel123
Thanks all! Whoa Ivan, that is cold!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- Has thanked: 1640 times
- Been thanked: 878 times
- Has thanked: 20448 times
- Been thanked: 10254 times
Great capture of the flare Warren!
- rigel123
Thanks Alan and Mark!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
