Still struggling for sharp focus in H-alpha. Cloudless sky, but low sun at 55N.
Hard frost 18F [-8C] air temperature. 21F [-6C] inside the dome meant dewed optics.
The flexible dome skirt was frozen in place with snow and ice until I cleared it all manually.
Hours of heat bands and repeated use of the hair drier on the D-ERF, objective, filters and etalon didn't help much.
Even the GPCs were misting over as I fitted them to the camera nose. More blasting with the hair drier.
I was getting a glazed, "frozen rain" look on every processed image out of ImPPG at default settings.
Imagined the camera sensor was dewed but it wasn't. SharpCap said the camera was at 23C [73F.]
So just before lunch I removed the entire H-a filter stack and etalon for a quick, white light capture.
Left the Baader D-ERF in place. Lacerta 2" wedge. ZWOASI174MM + 2.6x GPC on the 1.25" nose.
Not a great image but I have to be grateful for any sign of the sun in winter.
26.12.2021 AR2916 white light in snow and frost..
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
- Has thanked: 9319 times
- Been thanked: 6157 times
Re: 26.12.2021 AR2916 white light in snow and frost..
I think you did very well, Chris, with your high magnification image in the winter conditions. I also was out yesterday and the Ha proved very difficult to focus, still going through the results to see if there is anything worth posting.
This is a fine image and close-up of 2916 Chris - showing a lot of the detail surrounding the spots.
Thanks for your cold efforts.
- Has thanked: 17853 times
- Been thanked: 16996 times
Chris,
That one looks familiar!! Nice closeup!
- Has thanked: 8559 times
- Been thanked: 8291 times
Challenging conditions, Chris. Well done capturing this fabulous active region.
That sounds chilly so different to here in the UK where it is mild but cloudy. That's an excellent WL, you should take them more often
- Has thanked: 9723 times
- Been thanked: 5773 times
Hi Chris,
Excellent white light and definition ...
- Ivan
- Has thanked: 3485 times
- Been thanked: 2263 times
Well done Chris! In such cold weather, all wires turn to stone.
Ivan
Ivan
- Rusted
Thank you all for your kind words.
What can I say? I promise to do [much] better.
- Been thanked: 10489 times
That's a great close up of the spot Chris!
