Ca II K solar activity 30 Dec 2021
Has thanked: 174 times
Been thanked: 618 times
Post by Merlin66 »
After fighting the problems of poor USB3 cables all week I managed to find a cable combo which would give me 150 fps with the MiniSHG.
Today's disk shows all the prominent AR's, sunspots and filaments.
Solar disk in Ca II K
The "protus" image shows the large and bright prom.
Solar disk showing Ca II K prom
(Using a W47 + Astronomik L1 UV-IR + 1mm exit slit to suppress the background.) , I was pleased to be able to record the prom.
I now have a workable solution for H alpha and Ca II K/H. Just need some practise with the Na/ He/ Mg wavelengths. I do have a collection of green, yellow and other filters.
I'll probably give the MiniSHG a rest for a while and go back to my DIY 1A CaII K filter, Baader Wedge and the DS SM60.......
(BTW Does anyone have the transmission curve for the Lunt Ca filter? UV and/or NIR leakage??)
Has thanked: 17807 times
Been thanked: 16940 times
Re: Ca II K solar activity 30 Dec 2021
Post by DeepSolar64 »
Outstanding!!
Davidm
Has thanked: 1 time
Been thanked: 289 times
Post by Davidm »
Good one! Like the ghostly look of the first shot.
Lunt LS152T (DSII and CaK module), Coronado Helios 1, Grasshopper 3 2/3" CCD
Has thanked: 20732 times
Been thanked: 10427 times
Outstanding images Ken, really quite impressive what you are able to capture with the mini SHG. Please keep them coming.
Out of band blocking is always essential, in either filters or SHG it seems to give best contrast images.
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Super images, Ken. Very nice to learn more about imaging in the Calcium frequency ! Those proms are impressive.
Post by Merlin66 »
Thanks guys, appreciate the positive feedback.
I'll use the INTI software to prepare some images in the Ca II K2v and K2r regions as well as the extended Ca II K1.
Close up of K3 and K2 regions
Composite spectrum across the Ca II showing active and quiet regions
Ylem
Has thanked: 99 times
Been thanked: 25 times
Post by Ylem »
Amazing captures Ken!!
-Jeff :movie
Solar Newbie
Coronado PST,
Lot's of other astro stuff :lol:
Post by Merlin66 »
With the SHG processing software (INTI) you can apply a wavelength offset (in pixel) and use that data to prepare an image.
With my MiniSHG each pixel (at Ca II wavelengths) is 0.078 A.
The Ca II K3 is on the CWL (central wavelength), pixel offset 0.
The K2 regions are at +/- 0.2A = 3 pixel and the K1 further out.
I selected a pixel offset of 15 (1.2A) to record the K1 band. This would, I think, reflect the performance from the commercial Lunt filters.
The graph shows the position of the various Ca II regions within the Chromosphere.
RESULTS
K3 - T= 6500K, Height=1800 Km Shows the flocculation, bright active areas, filaments and proms
K2v - T= 6000K, Height= 1000Km Shows the flocculation as more uniform, active areas, sunspots, filaments and proms - faintly!!
K1v - T= 4500K, Height= 500Km Shows a more granular surface, active areas, plage and more defined sunspots (umbra/ penumbra) - little !! evidence of proms
Details of proms (or lack thereof!)
Gold standard stuff there Ken, thanks for the additional info.
Has thanked: 8523 times
Been thanked: 8251 times
Post by Carbon60 »
Very impressive, Ken.
Has thanked: 17888 times
Been thanked: 8887 times
These are incredible Ken :bow :bow :hamster:
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Indeed what more words can describe the incredible and beautifully-coloured captures Ken.
Perhaps the most interesting Calcium images of 2021.
Thanks vm and H.N.Y.
Post by Merlin66 »
Thanks guys I appreciate the positive feedback!!
(I did look at the possibility of getting images in the Mg II K3 wavelength which lies at the top of the chromosphere (2,000 Km) and 8,000K (approx) See graphic above)
Unfortunately these Mg II lines are only accessible from spacecraft! They sit in the UV at 2796.34A (k) and 2803.52A (h)
https://www.aanda.org/articles/aa/pdf/2 ... 128-15.pdf
Looks like I'm limited to the usual suspects - Ca II K/H, H beta, Fe, Na, He and H alpha.
Ken,
Nice CaK work. I want badly to get into CaK or CaK observing and imaging. I would use a monitor to do visual. The dang Lunt modules go sky-high when I start planning to get one.
http://daystarfilters.com/Quark/MgIQuark.shtml
Can you image the magnesium line the magnesium Quark sees using your mini SHG?
Post by Merlin66 »
James.
Yes , should be an easy target. The Mg I (b2) absorption line is the middle of the Mg triplet, at 5172.8A
I'll image there when I restart the MiniSHG.
Been thanked: 4957 times
Post by eroel »
Ken:
Super CaK images and information.
Best wishes for this rapidly coming New Year.
Post by Merlin66 »
Thanks Eric.
If I only had the seeing conditions you have I'd use the MiniSHG with a long focus refractor to get some CaK close ups. I'm envious of your results!
Merlin66 wrote: Sat Jan 01, 2022 1:38 am James.
Ken,
I look forward to seeing your Mg 1 ( B2 line ) SHG images. Mg is highly underrepresented here. That to me is the greatest thing about an SHG. They can image wavelengths off the beaten path!
HNY
Post by Merlin66 »
Jame,
Definitely one of the strengths of the digital SHG.
When you add up all the costs of the various Lunt, Coronado, Daystar filters you would need to cover the more interesting wavelengths it would be a few thousand dollars…….a MiniSHG can be constructed for around $1000, including the camera!
Bang per buck the SHG wins hands down.
Oh, and it never deteriorates over time or needs expensive maintenance or repair.
What cadence could you record full disk images at Ken?
Post by Merlin66 »
Mark,
I usually scan the solar disk in 9 sec, at 250 fps.
So it would be possible to capture 5 or 6 a minute then give or take? You could take 10 or so disk images and then stack then in AS3, should iron out some noise...
Post by Merlin66 »
Mark,
Yes, that would be possible.
INTI only takes a few seconds to process an image.
I have stacked four images, worked OK. As the position of the image within the frame depends on the scan start and stop position (and also the positioning of the spectrum within the slit gap) registration can be difficult at times.
Merlin66 wrote: Sat Jan 01, 2022 9:17 pm Jame,
That's a BIG plus! I wonder why no one has produced one commercially for sale?
Post by Merlin66 »
Good question!
In a previous life I’d be more than prepared to give it a go. (That’s how the Spectra-L200 was designed and commercialised)
This time round I’ll leave it to others..There’s a manufacturer interested but doesn’t seem to have the drive!
The market isn’t big.
There’s a few trip hazards which need attention to detail.
Has thanked: 64 times
Been thanked: 4406 times
Post by MapleRidge »
Hi Ken...
Great shots and I appreciate the additional data you have included too :bow
