Flare Fishing 26 Dec. 2021
- dccole9
- Has thanked: 42 times
- Been thanked: 34 times
I went "flare fishing" again on the 26th of December in an attempt to capture a flare after 3hr+ of recording. I'm fairly certain I got one near Active Region 2920 at about 20:30UT so I thought this was worth posting. Is there anywhere I can look to confirm this?
https://youtu.be/COoSTMrOYt8
Chris
Chris
Lunt LS80tHa
Lunt Herschel Wedge
Lunt CaK B1200 module
ZWO ASI174mm, ASI183mm
Flickr site: https://www.flickr.com/photos/dynamic_universe/
Lunt Herschel Wedge
- Has thanked: 17849 times
- Been thanked: 16989 times
Re: Flare Fishing 26 Dec. 2021
You can use the Helioviewer image viewer to do so. Put in the date and time and choose the spacecraft and instrument you want to use. You can even layer the images from two different spacecraft or use two different instruments on a spacecraft.
https://www.helioviewer.org/
Give it a try!
P.S. It certainly looks like you caught a couple of flaring areas.
Give it a try!
- Has thanked: 8558 times
- Been thanked: 8288 times
Nice one, Chris.
- Has thanked: 20803 times
- Been thanked: 10478 times
Nice vid, you got a small filament lifting off rather than a flare.
- Has thanked: 1640 times
- Been thanked: 878 times
- rigel123
- Has thanked: 8573 times
- Been thanked: 8806 times
Definitely an eruptive filament lifting off to the right of that AR after it appears to display a small flare event.
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
That is a great filament lift off
Best place to check flares are here and hover over the chart for more details
https://www.spaceweatherlive.com/en/sol ... lares.html
https://sohowww.nascom.nasa.gov/ is the originating satellite for showing flares and typically using their MPEG or GIF movie tab, the latest flares can be seen in as higher resolution as practical..
https://sohowww.nascom.nasa.gov/data/realtime/gif/ for example...
There are many other pages on the SOHO website and of course The Solar & Heliospheric Observatory/SOHO satellite was launched in 1995 - 26-years ago !!!
Currently it anticipated to remain in service until 2025 (30-years) and some of the equipment on board was designed and manufactured - just up the road from me. Almost incredible for any Solar-imaging satellite to be in service for that long, and presumably may remain so for even longer...
Further details available from E.S.A's PDF as https://sohowww.nascom.nasa.gov/about/d ... _Sheet.pdf
I must add to my reports here on SC, more from SOHO as and when in future...
H.N.Y.
H.N.Y.
- dccole9
All,
Thank you very much for the references and encouragement. My goal right now is to make the images more presentable which means more processing practice.
Of course, the biggest prize is to capture an X-flare.
Thanks Again,
Chris
Thanks Again,
Chris
Lunt LS80tHa
Lunt Herschel Wedge
Lunt Herschel Wedge
- Been thanked: 4426 times
Great animation Chris
I'd agree to a small flare, but the eruptive filament is the best catch!
